on the Z51 bubble
Someone sell me Z51 at $2800.
At $2800 it sells itself.
If you're going to track the car, then it's a no brainer.
Well, I presume you already know what you get with it, right - i.e. nicer wheels, heat exchangers, dry sump, mag ride/PTM, e-diff, brakes, tires, etc.
So, are those items important to you enough for 2.8 k or not? If so, get them; if not, don't. |
At $2800 it is the bargain of the year !!:thumbs::thumbs:
Originally Posted by OnPoint
(Post 1584239317)
So, are those items important to you enough for 2.8 k or not? If so, get them; if not, don't. I think the Mag Ride is not included w Z51. If it was that would literally be the deal of the century. :yesnod: |
Originally Posted by Zymurgy
(Post 1584239294)
Larger brake rotors Dry sump oiling Limited slip differential Larger wheels More aggressive gearing Larger spoiler Split spoke wheels Am I missing something? |
Do you have a coupon ? :eek:
Z51 Performance Package, includes (J55) performance brakes, (J6A) Black-painted calipers, slotted brake rotors, (Z52) dry sump oil system, (FE3) Z51 performance suspension, specific shocks, springs and stabilizer bars, (XFJ) P245/35ZR19 front and P285/30ZR20 rear tires, (Q7S) Silver-painted aluminum, 19" front and 20" rear wheels, performance gear ratios, (G96) Electronic Limited Slip Differential (eLSD), (KNR) rear differential cooler, transmission cooling and an Aero Package.
Originally Posted by 89L98
(Post 1584239343)
Yup - I think you're right. Even without that, IMO the package is worth it. I can see, tho, where others might not want it/need it. |
All the nice stats introduced this past week from Virginia Speedway were truly impressive. They were achieved with a Z51 equiped car. If performance is important, I would not hedge a bet against it. Go for it!!! Plus the physical attributes of the car look better IMHO. If you dont do it...the odds are you will regret it. Good luck :cheers:
(Post 1584239355)
You are KIDDING right???
Based on the equipment, many on this board were guessing between 5 and 8k for this option, and it's 2800 and you need to be sold on it???? Forget tracking the car as the reason, although thats a good one, looks, rims, resale, eLSD, coolers, IT"S AN EASY choice...
(Post 1584239355)
(Post 1584239368)
Even without that, IMO the package is worth it. I can see, tho, where others might not want it/need it. :iagree: :cheers: |
Originally Posted by AVETTE
(Post 1584239383)
That option and all others will be 100% depreciated when you drive it off the lot. Sorry to break it to you guys. :ack: |
Originally Posted by c5vette73
(Post 1584239415)
When I sold my C6 Z51, the Z51 option added ZERO value to my car.
Z51 is a gateway option. Well worth it for what it is, but it's what it lets you get that is important. Spoiler, wheels, MSRC...
(Post 1584239383)
So its worth $2,800 just to say I have a Z51 equipped C7? Aftermarket wheels and spoiler will be much cheaper than $2,800. |
(Post 1584239415)
