Do you guys wax your windshield?
Hey guys,
I recently made this video and just wanted to share. Although in the video is a truck and not the Vette, this is the same procedure I use for my C4. Below are pics of the Vette after I cleaned and waxed the windshield! What do we think? http://forums.corvetteforum.com/memb...open-49593.jpg http://forums.corvetteforum.com/memb...ette-46487.jpg |
I have always waxed glass after cleaning with a razor and Windex. :)
I do.
Does it matter which kind of wax?
I have meguiers cleaner wax. |
never waxed my windshield, but I do use adams detailing spray on the glass. doesn't seem to cause any issues.
i have not waxed the windshield. what are the benefits, other than the obvious water beading properties?
I sometimes use Rain X.. :thumbs:
I used to. It begins to cause the wipers to skip around the glass. If you do it, make sure to keep your wipers clean all the time.
Originally Posted by Joe C
(Post 1584340994)
Originally Posted by 91 corvette
(Post 1584341213)
That's what I do too. Works better than glass cleaner.
Originally Posted by TorchTarga94
(Post 1584341187)
Jim G |
I tried Rain X when it first came out and didn't like the results. I've never tried wax or detail spray but I think I'll give it a try.
dogfish I've been missing your videos, you don't post them very often anymore. |
Back in high school, when I was driving my first car (1948 Plymouth, 4 door special deluxe), I was told by my hot rod neighbors that polishing a windshield caused bad glare at night. I was 16 at the time (am now almost 63) and did it anyway, cause I liked the reflections and the look of it. I find the glare much less than Rain X, and continue to wax the windshield on all my cars.
I have done both wax and rain X. Since it rains so much in South Fla, I tend to like RainX a lot more.
Originally Posted by JimGnitecki
(Post 1584341690)
That COULD cause the wipers to "collide", and that could then cause a breakage in the pin mechanism inside the wiper motor cover, causing the wipers to not be able to park, and thus not shut off when you want them to.
Jim G |
Good video
I've been using Griots Glass Clay (with Griots Speed Shine for a lubricant) and Stoners Invisible Glass. It only takes a few minutes to clay-bar a windshield...just like with paint, claying is a good prep for waxing or polishing glass. |
Originally Posted by vettestrings
(Post 1584343021)
Good video
I've been using Griots Glass Clay and Stoners Invisible glass. It only takes a few minutes to clay-bar a windshield...just like with paint it would be good prep for waxing glass. I do that also, but follow that with a coat of Rejex and then wipe that when it dries. Bugs don't stick! Most just bounce off and the juicy ones will wipe off with a paper towel after they dry. I usually don't even have to use the wipers at all because the water droplets just flow off the glass from the wind. At night, when it's raining, as long as there are no other light sources close by, you can't even tell that rain is hitting the windshield. It makes the rain hitting the windshield almost invisible. I haven't had any glare issues either. I think cleaning and prep before you apply it keeps the smear/glare from being a problem. |
Originally Posted by GQ-ROD
(Post 1584340993)
Originally Posted by mazdaverx7
(Post 1584341120)
Originally Posted by mrmtrtrnd
(Post 1584341854)
