For Sale: One of the most highly modified ZO6's in the country
Those that are familiar with me here on the forum know my car and know it has the absolute best of everything with nearly 200k invested in the build. For those that don't, here is a description of what has been done with the car I have owned this car since new, purchased in 2007 and it's gone through a complete transformation since I've owned it. The car currently only has 15,000 miles on it. Only 1000 miles on the new engine build. The car has not been to the track a single time with the new engine build, but I assure you it will run well into the 8's The car makes an honest 1070+ HP to the wheels through a 4L80 automatic transmission. Despite being an 1100 HP car this car is super reliable and you can drive it anywhere with cold A/C blowing in your face. The street manners of this car are incredible and driving around town with the auto a pleasure. Engine built by Erik at HKE LSX Block Callies LS7 Ultra Billet Crank Carrillo Rods Wiseco LS 4.155" bore 4.00" stroker forced induction piston 9.6:1 compression. Tool steel piston pins for FI. Total Seal Piston Rings for FI Mast Rectangular Port LS7 12 Degree 6-Bolt Large Bore CNC Assembled with Lunati Dual Springs and Hardware Trend hardened pushrods Cometic LSX Head Gaskets ACL coated main and rod bearings ARP Main Studs ARP2000 Cylinder head studs New LS7 Hydraulic Roller Lifters Dallas Performance custom grind DP-7X Blower Cam as mentioned already... this car and engine have the absolute best of everything throughout and built to handle 2000 WHP. DeWitt's radiator Methanol injection system Dallas Performance fuel system To handle the power reliably RPM Transmissions did the 4L80 automatic transmission conversion. The transmission and differential are built to RPM's Level 7+ specifications and has the best parts available including 300m input/output shafts. The trans is equipped with a transbrake. Car also has a line lock. Also installed is DSS 1000HP rated half shafts. These are brand new and have a lifetime warranty. Supercharger system includes custom overdrive 8.5" crankshaft pulley with 2.8" head unit pulley, brackets, intercooler, Vortech YSi head unit, dual TiAL Q 50mm blow off valves. This is a 10 rib driven supercharger. Best of everything!! Dallas Performance flip drive with ZR1 compressor (6 rib) driving the system. No puny 4 rib like with other flip drives. Compressor is brand new. Dallas Performance billet alternator. This is the only thing that holds up on these cars making this much power. Other than the transmission conversion, Dallas Performance performed all work on the car. Tuning was done by Taylor Sims. Other amenities include a genuine ZR1 carbon fiber roof genuine ZR1 carbon fiber roof halo ZR1 fenders ZR1 side skirts and front splitter Custom 3 piece wheels with real carbon fiber face, chrome wheel hardware, red pin striping, painted inner and outer barrels, tire pressure sensors and new Michelin PS2 Cup tires Interior features new upgraded 2012 ZO6 seats Custom APSIS door panels with carbon fiber inserts, leather wrapped with red top stitching. APSIS carbon and alcantara steering wheel with custom center emblem to match emblem on custom wheels. Custom interior arm rest, shift boot, brake lever boot 6 point RSD roll bar with removal door bars The complete interior is laid with Dynamat Xtreme sound deadening / heat insulation. Akrapovic Exhaust Kooks Ceramic Coated stainless steel headers and X pipe 2 piece light weight brake rotors Rear C5 brake conversion with LG billet spindles (to allow use of 15" rear drag wheels) I still have stock ZO6 rear brakes/spindles. Pfadt coil over suspension with Pfadt rear drag bar. I'm sure there are many things I'm missing, but I can tell you this is one of the most built up ZO6 on the streets in the USA. The car is perfect in every way and there has been no expense spared in the build of this car. Only the best and strongest parts have been used. This is a new car! New Engine! New transmission/differential! New interior! New everything!!! I'm listing this car at a sale price of $86,900 The car cannot be duplicated for double that amount. The car is a black car, but I recently had it wrapped in a Satin Pearl White. It's absolutely gorgeous! The wrap was done professionally in Dallas when Dallas Performance had the car for the work. If you have any specific questions let me know and I will be happy to answer in great detail. Taylor Sims at Dallas Performance can also be contacted with any questions regarding the build. Enjoy the pictures. If you want pictures of something specific let me know. Thank you, Jerry Gaddis http://i130.photobucket.com/albums/p...ps8791dcac.jpg http://i130.photobucket.com/albums/p...ps381a78f1.jpg http://i130.photobucket.com/albums/p...ps23392926.jpg http://i130.photobucket.com/albums/p...ps79fdd022.jpg http://i130.photobucket.com/albums/p...ps69d1a97c.jpg http://i130.photobucket.com/albums/p...psdf895ac7.jpg http://i130.photobucket.com/albums/p...ps86f99413.jpg http://i130.photobucket.com/albums/p...psb3f4e7a7.jpg http://i130.photobucket.com/albums/p...ps946385b5.jpg http://i130.photobucket.com/albums/p...psb1c62338.jpg http://i130.photobucket.com/albums/p...psd2d0d0a3.jpg http://i130.photobucket.com/albums/p...psc215a9af.jpg http://i130.photobucket.com/albums/p...ps15baab1d.jpg http://i130.photobucket.com/albums/p...psaaec6c63.jpg http://i130.photobucket.com/albums/p...ps90a1b2a3.jpg http://i130.photobucket.com/albums/p...ps1ced8247.jpg http://i130.photobucket.com/albums/p...ps1e10bf2a.jpg http://i130.photobucket.com/albums/p...psa999c076.jpg http://i130.photobucket.com/albums/p...psaacc4093.jpg http://i130.photobucket.com/albums/p...ps57c0d4f1.jpg http://i130.photobucket.com/albums/p...ps8ae24528.jpg http://i130.photobucket.com/albums/p...pseee64c31.jpg |
simply put WOW!!!!!!
Originally Posted by flea_sly
(Post 1584549409)
Thank you :) |
Simply amazing. I have absolutely no ability to buy this car but would love to see some video. If I were in the market for a ZR1, I'd get this instead.
well
just when I think I have seen it all, how can you even think of letting it go??:cool:
The wrap really transforms this car - stunning.
sick... just sick.
The wrap is looking really good. What a transformation in the appearance department. Over $200k invested for $98k is a steal. Good luck with the sale!
This car makes a divorce tempting... ;)
(Post 1584549409)
Thanks for the complements guys. Someone is going to get one hell of a supercar for a fraction of the build cost!
Jerry |
I've been getting a lot of PM's asking what options the car has.
It's a fully optioned car and still has the factory nav unit. Everything works in the car. This car needs nothing! Thanks! |
Originally Posted by radstom
(Post 1584554415)
Price reduced to $89,900
Amazing car.
I just took a quick video for you guys. Just in a knick of time before the rain started :)
That is one bad Azz ride good luck with the sale
Wow, uber impressive car!
Just when you think you have seen it all...Wow!:cheers:
Holy crap. This car is so bad ass, my testosterone levels just plummeted because I now know something this bad ass even exists and I do not own it. wow wow wow wow. I would love to see her in person sometime. Congrats to whoever buys this car.....
