1978 Courtesy timer location ????
I finally got out to my car to try to get to the timer for my courtesy light . I removed the interior of the glovebox . Nothing , I found nothing that resembles the timer anywhere behind there . WTF , I'm miffed . It looked so easy in the pics someone posted for me . This is typical for the way things go for me . I also took out the air duct on the passenger side .
On my '79 its right there where you described. I believe that it is orange in color and taped along the inner right side of the dash pillar. Maybe yours was removed?
I'll take a pic if you want... |
77 it was taped to the harness right between the speedo and tach.
Originally Posted by TimAT
(Post 1584595870)
Originally Posted by 79vetter
(Post 1584595838)
On my 78 it is accessed by removing the glove box interior and it was on the right hand side on the pillar. It is a plastic box about 1.5 inches wide by 2 inches tall and about .5 inches thick if memory serves me correctly. At least gives you an idea of the size and location. I have no pictures when I replaced the circuit board inside the box.
I am going to reach in there tomorrow and see if i can feel it . It is definitely not visible when you open up the glove box . Is the timer taped to the pillar or screwed down . I don't think I can do the job if it is screwed down . I really want to get this done . I am very frustrated . I am not the greatest at doing stuff but I thought I could handle this job . Thanks everybody . :thumbs:
On my '80 it is behind the glove box as well- orange plastic box about the size/shape of a deck of cards. Pretty hard to miss (unless of course the PO removed it). Good luck.
Is this it?
http://i1323.photobucket.com/albums/...ps762db87a.jpg Under pass. side dash on my 79. As you can see, I've got stuff under there that seems to be unplugged :( (Post on that coming soon) Good luck! |
Originally Posted by cb98coupe
(Post 1584597043)
Went behind the glovebox this morning again . I felt around to the right of the glovebox and also by the a pillar , nothing . It has to be there because the courtesy feature worked until it started giving me a problem . I am gonna keep looking . I don't want to have to bring the car to a mechanic for this . :thumbs:
Originally Posted by desue
(Post 1584598022)
Is this it?
http://i1323.photobucket.com/albums/...ps762db87a.jpg Under pass. side dash on my 79. As you can see, I've got stuff under there that seems to be unplugged :( (Post on that coming soon) Good luck! I have all the bulbs out and let the car sit overnight and the battery did not drain so that's a plus . Started right up . When I removed the fuse the power antenna did not work . |
Isn't there a way to jumper a couple of those wires to bypass the timer,, i can't remember whitch ones ..
Here's mine - its loose - not taped at the moment but its right there :)
http://i805.photobucket.com/albums/y...psbc37dd03.jpg |
Been trying to find my courtesy timer too,, Hadn't thought about taking the glove box out,, well I took it out and I found the timer, it had been disconnected and the connector was beside it.. Plugged it in and it works perfect.. also found a small round blue thing towards the back that says flasher on it.. I have no idea what it's for..
http://i1149.photobucket.com/albums/...ps996ee45a.jpg |
Man , I am going crazy over this thing . I even crawled underneath the dash and nada , nothing . I have an appt. friday with a mechanic . to try to figure out what the heck is going on . I will update when I have more news . There is a silver thing that looks like a flasher that I found . Oh well , thanks for all the replys . :thumbs:
My car was built 11/77 .
Here is the inside of my glovebox . Everything is pretty neat and doesn't look messed with . The round silver thing is the only thing I found .
http://i160.photobucket.com/albums/t...3/100_0531.jpg |
Initially GM had plans to put the timer behind the speedo tach housing.. you can view a picture of this in the Assembly manual on page 506 or section 12l sheet 9.
I've never seen a car with one back there.. they have all been located behind the glove box. On the 80 we just installed a dash pad in the timer was way around the corner and only visible if you looked from under the dash pad. http://willcoxcorvette.com/images/de...0locationi.JPG Here is the 80 showing you in the right hand corner. https://sphotos-b-iad.xx.fbcdn.net/h...68107470_n.jpg |
I found my courtesy timer and also the round blue thing.. Dont know what it is but it has a bracket around it that isnt fastened to anything..
http://i1149.photobucket.com/albums/...psd5919fe0.jpg |
