-   C7 General Discussion (https://www.corvetteforum.com/forums/c7-general-discussion-142/)
-   -   DIY, FAQ's, TIPS and Announcements (https://www.corvetteforum.com/forums/c7-general-discussion/3403434-diy-faqs-tips-and-announcements.html)
Zymurgy 01-12-2014 09:40 PM
This sticky will be used to post links to various DIY projects, Frequently Asked Questions, etc. If you know of a thread that should be added here, please PM me with a link to the thread. Threads should only cover one DIY project or FAQ.
Announcement Threads
Grand Sport Announcement Thread
2014-2015 Removable Roof Panel Noise Bulletin
DIY Projects
FYREANT's Instructional "How To:" guides
Master List of How-To Guides for C7 Corvette Stingray
Brake Pad Replacement - Quick and easy Z06 Brake replacement to Carbotech 1521s
Carbon Fiber Wheel Center Caps
Carbon Fiber Dash Install
Carbon Fiber Dash Install Step by Step
Carbon Fiber Dash Install with Video
Corsa Double Helix X-Pipe Installation-Thoughts and Opinion
CQuartz - Quick and Easy CQuartz Finest Application
GT to Competition Seat Conversion How To
Master List of How-To Guides for C7 Corvette Stingray (thanks to member Theta)
How to Install Aero Front Plate Holder
How to Install Sound Deadening
How to Install Sound Deadening - Fantastic Results Soundproofing a 2018 Grand Sport
How to Remove Door Panels
How to Install NavTool
How to Remove Rear Hatch Interior
How to Replace the Battery
How to swap C7 floor mat retaining clips
Lowering On Stock Bolts
Installing AccentGlow Cup LED Holders
Painting Trim in Carbon Flash
Painting coil pack covers and other engine covers
Reducing Orange Peel
Rear View Mirror, Reading Lamp, A-Pillar Interior Trim Removal
Switched AUX power jacks - making them always hot
Staining Interior Stitching
Steering Wheel Swap
Visor Warning Label Removal
Front Bumper Cover Removal
Removing and Replacing Wiper Arms and Windshield Cowl
DIY: LTI intake valve cleaning/cleaning deposits.
FAQs
Body and Wheel Touch-Up Paint Codes
Official GM stance on free oil change intervals
Tire skipping, chatter... It is normal?
Must change oil on dry sump Corvettes at 500 miles
GPS Red X "Fix" (2015 with PDR)
New to the Vette? NORMAL things the Vette does.....
What goes in the indentation in the battery cover? (see question 8 in this list)
What are the gear ratios? - A6 and MN7
What are the gear ratios? - A8 and MN7
Where is the battery located?
Where are the remote positive(+) and negative(-) terminals under the hood?
Mobil 1 Use ONLY - Official dealer notice to use Mobil 1 in all C7s.
PROOF--The 500 mile oil change is free, and does not count toward service.
TIPS
Emergency Battery Access
Adjusting seats for maximum leg/head room
Delivery Inspection Checklist
Everything You Wanted to Know About Your FOBs and RKE
Genie Garage Door Openers and Homelink
Stingray/Siri integration
Save the Wave :seeya
Tips and Tricks
