-   C1 & C2 Corvettes (https://www.corvetteforum.com/forums/c1-and-c2-corvettes-4/)
-   -   Converting Caliper Lip Seals to O-rings (https://www.corvetteforum.com/forums/c1-and-c2-corvettes/3407656-converting-caliper-lip-seals-to-o-rings.html)
JohnGibson 01-20-2014 07:52 PM
I am wanting to convert my calipers to O-rings from lip seals since they are leaking. When converting, do I need to buy new pistons or will my current ones work?
jrm5657 01-20-2014 09:49 PM
http://www.keenparts.com/pages/detai...partnum=500322
http://www.keenparts.com/pages/detai...partnum=500323
They come as a kit with the pistons. If your calipers are already sleeved, just pop these in for $80 and you will be all set.
wraplock 01-20-2014 10:02 PM
It is actually a very simple and straight forward install. The kit will come with easy to follow instructions. I found it much easier than replacing the lip seals. I already had swapped out my calipers for the Stainless steel ones from Vette Brakes so all I needed to do was clean them up a bit with some 2000 wet/dry sand paper with a little brake fluid. I then rinsed them out good, wet the bores and the o-rings with a bit of clean brake fluid and install.
Don
Chuck Gongloff 01-21-2014 06:44 AM
4 Attachment(s)
Fairly routine job.
Here are some pics I took when I did the calipers in my 69.
My kit came from Vette Brakes & Products.
Chuck
65silververt 01-21-2014 10:11 AM
Just be careful installing the lip seals. It's easy to screw them up if you tap too hard too soon.
JohnGibson 01-21-2014 11:31 AM
I have been unable to check today since too cold, but will the o-ring kits work with calipers that don't have ss sleeves installed? Not sure if mine have them or not.
stingrayl76 01-21-2014 12:43 PM
If your caliper bores aren't pitted and just required a light honing, you won't have to have them sleeved. The O-ring pistons and seals will work fine.:thumbs:
