Front Spoilers?
Okay so the approach to my Driveway is deep. Backing out the M/H leaves cuts in the street from the trailer hitch....Added Air Bags to fix that.
Now the Corvettes are different...They drag going in. The 1973 without a front Spoiler/Air Dam just clear. The 1993 and 1994 drag going in and backing out I I hate the sound. So does the front spoiler/Air Dam really do anything...Remove it completely or maybe just take a cut off wheel and trim it up where it drags. Thanks Karsten |
The front spoiler directs air flow up into the radiator area when going down the road. The stock design will flex and give, so it would be best to leave it alone.
The air deflector on my '84 got damaged about 20 years back running up to one of those concrete barriers they put in front of parking spaces. I removed it and never had any overheating problems so I'm not sure just how effective these are in re-directing air flow and improving cooling. You might try removing it and check if the running temperature is significantly affected by the change. A couple of degree increase shouldn't be a problem. On the other hand, if the fan(s) turn on when you're at highway speeds (A/C turned off), you probably will need to reattach it.
There are two versions of the front air dam. The Z51 version is 1" taller (hangs down 1" lower) than the stock one. If you have a Z51 car it might help to switch to the shorter version.
Originally Posted by Cliff Harris
(Post 1586057097)
Originally Posted by corvetteronw
(Post 1586053334)
Buy one of these:
http://ecx.images-amazon.com/images/I/51SMZ8VJDcL.jpg BRIDJIT 3-Piece Expandable Curb Ramp Set, 12-Feet of Driveway Coverage: Amazon.com: Industrial & Scientific Jim |
This is where I bought mine, good quality, fast shipping, great price......WW
http://www.ebay.com/itm/C4-FRONT-SPOILER-CORVETTE-COMPLETE-AIR-DAM-KIT-91-92-93-94-95-96-PROPER-AIR-FLOW-/141098590126?_trksid=p2054897.l5658#ht_2696wt_1000 |
Originally Posted by jim02C5
(Post 1586898736)
I have one of these. Works good but I hate having to drag it back in place every couple of days.
Jim [url="http:// Put a seam of "Liquid Nails Construction Adhesive" under it, it won't move till you pry it up..Trust me on this.....:thumbs:.....WW |
The C5 spoiler is hinged..... you might research to see if the C5 spoiler will fit and perform.
[QUOTE=WW7;1586899844]http://ecx.images-amazon.com/images/I/51SMZ8VJDcL.jpg
[url="http:// Put a seam of "Liquid Nails Construction Adhesive" under it, it won't move till you pry it up..Trust me on this.....:thumbs:.....WW[/QUOTE] Been considering drilling a couple holes and putting a spike or nail of sorts through to where I could still pull it up to get all the crap that gets under it. Leaves and dirt and whatever else...alot gets trapped under mine and is probably why it slides so much. That and the way I enter the drive from an angle. Jim |
(Post 1586902370)
Jim I replaced it and there is a HUGE difference. Runs cooler and looks better. I think it is an important part of the cooling system. Chris |
Wish someone would offer a shorter air dam assy for lowered C4's. Bet they would sell a bunch of them.
My way of dealing with this situation is to always keep a spare spoiler on hand and when the one on the car gets in bad shape I change it for the new one. They are not that expensive and Corvettemods has them on sale for $46.99 for all 3 pieces. http://forums.corvetteforum.com/c4-g...e-46-99-a.html I just put a new one on this year and bought another spare from them. Maybe not a suitable solution for everyone but it works for me.
Originally Posted by Midnight 85
(Post 1586912380)
Originally Posted by WW7
(Post 1586912866)
They must not sell Duct Tape in your area....:rofl:...WW
