Adjustments for adding bigger tires?
Thinking about changing my base OEM tires to Z51 size tires. Will the computer need to be adjusted for Active Handling, Traction Control, etc?
no
Originally Posted by Ronbear
(Post 1586458166)
If you move from base wheels and tires to Z51 wheels and tires, the rolling diameter is the same so no change.
The only difference in base/Z51 is the 18/19" vs 19/20" wheel (the width of the tires are the same) but that difference in diameter is offset by a smaller profile tire on the Z51. |
Originally Posted by gthal
(Post 1586458593)
