73 Master Cyliner Vacuum Booster
Hi all,
It's been a while since I've checked in. I found my 73's MC leaking so I ordered a replacement combo MC/PB from Zips but the MC did not fit the PB so I sent them back. So I ordered combo MC/PB from Ecklers and the 2 parts fit properly so I installed them. Interesting findings: there was quite a bit of surface rust on the braketry under dash so I cleaned as best I could and sprayed some neutralizer on them. Also had to drill out top 2 holes in firewall a little, bolts looked like 3/8" and 3/8 bit cleared out some, still didn't fit, checked bottom holes and found next drill bit size up cleared holes so I drilled top 2 and PB then fit So, all is good, bled MC (what a pain), then all 4 wheels with wife on break pedal and me on bleeders. Did this about 3 times and filled about a large asparagus jar (quart+ ?), used 1.5 quarts of dot 5 so far. here's the rub, the brake pedal seems hard with engine not running but almost goes to floor with engine running. Thus the multiple bleed attempts. Took the car out in the cul-de-sac for test and brakes stop car well, actually feels like it's got power now (not so much before). So where am I going wrong here? BTW, the MC/PB came with a short push rod and some type of puck insert but also a longer push rod. As the original had a long rod I used the long rod. Any advice from you all would be greatly appreciated. (missing another car show this weekend. dang!) |
you are supposed to measure the distance between the end of the rod and the piston in the back of the master. Were the two rods the exact same length? Do you have the factory service manual? You bench bled the master? Read the section on pushrods
http://www.classicperform.com/TechBo...oubleshoot.htm |
Originally Posted by MelWff
(Post 1587172172)
I bench bleed the MC, I tried to test fit the short rod and puck but the MC did not seem to fit flush on the PB, so thus the long rod decision. I also forgot to mention that I purchased some speed bleeder so I can do this myself as the wife is not always available. However, I did not measure the distance before assembly but would think that if came as a set it should work without modification. Just don't know if supposed to use the short rod w/puck thingy or the long. Eckler's tech advise was limited :) |
so you dont know the clearance between the end of the long rod and the piston in the back of the master? Can you try to measure with some clay or similar substance or observe how far in or out the long rod is from the booster mounting surface and also the position of the master piston with regard to the booster mounting surface. Too much distance and you get excessive pedal movement.
(Post 1587172319)
I tried to take the MC off w/o remove brake lines again but would only back off a little. However, I read where someone suggesed removing the bolt that holds the switch the line connect to from the chassis and then the lines would all move together. I might give that a try. So I was wondering how one measure a confined space like that, using clay huh? Otherwise off the MC brake line come again! Do you have any idea why the send out 2 different types of push rod assemblies, I'm guessing the short rod & puck would be a tighter fit as my test fit suggested? |
Originally Posted by Basque32
(Post 1587172154)
Hi all,
It's been a while since I've checked in. I found my 73's MC leaking so I ordered a replacement combo MC/PB from Zips but the MC did not fit the PB so I sent them back. So I ordered combo MC/PB from Ecklers and the 2 parts fit properly so I installed them. Interesting findings: there was quite a bit of surface rust on the braketry under dash so I cleaned as best I could and sprayed some neutralizer on them. Also had to drill out top 2 holes in firewall a little, bolts looked like 3/8" and 3/8 bit cleared out some, still didn't fit, checked bottom holes and found next drill bit size up cleared holes so I drilled top 2 and PB then fit So, all is good, bled MC (what a pain), then all 4 wheels with wife on break pedal and me on bleeders. Did this about 3 times and filled about a large asparagus jar (quart+ ?), used 1.5 quarts of dot 5 so far. here's the rub, the brake pedal seems hard with engine not running but almost goes to floor with engine running. Thus the multiple bleed attempts. Took the car out in the cul-de-sac for test and brakes stop car well, actually feels like it's got power now (not so much before). So where am I going wrong here? BTW, the MC/PB came with a short push rod and some type of puck insert but also a longer push rod. As the original had a long rod I used the long rod. Any advice from you all would be greatly appreciated. (missing another car show this weekend. dang!) 2) Are both boosters the same? 3) Given that it's a kind of important part of the car- the ability to stop - I would suggest pulling the m/c off. Brake fluid is a lot cheaper than death. |
Originally Posted by davidchristopher
(Post 1587172570)
1) You buy asparagus in jars?
2) Are both boosters the same? 3) Given that it's a kind of important part of the car- the ability to stop - I would suggest pulling the m/c off. Brake fluid is a lot cheaper than death. Well good question #2, they look similar in size but the MC bale does hit the check valve, so ? #3 can't disagree with common sense :) Thanks for the reply |
(Post 1587172631)
Yes to #1 when it's pickeled
Originally Posted by J.Abbott
(Post 1587172709)
What brand booster did you buy from Ecklers? The only booster that is made that is new is by MBM which is what we sell plus everyone else. Unfortunately they decided to use a 10mm stud in it instead of a 3/8. They are a little difficult to get the retaining nuts on but using wrench they will go on. Curious as to what issue you had.
In hind sight I would have actually preferred the Zips combo product as the MC had bleeders and supposedly the original manufaturer numbers. However, when the Zip person I spoke to said that I would have to drill out (MC I assume) to make it fit, is when I said no. The Ecklers MC had no numbers/bleeders but fit, however the bale closest to PB hits the PB check valve, so much for after-market. NBD, as I'm keeping the old parts and will most likely get them rebuilt by hopefully someone reputable at some point. Just want to get the car back on the road! Yes, I believe both the MC and PB boxes showd MBM now that you mention it. |
Just changed my Master cylinder on my 75. Bought a new one from Advance Auto parts "Cardone Select Master". It was a perfect fit. Bench bled the MC before putting it in the car. All fittings were identical. Bled all the brakes and exchanged all the old fluid in the process and now good to go. :thumbs:
Originally Posted by dtianen
(Post 1587173111)
This is probably all the OP needed to do, don't know why the Booster was replaced when the Master Cylinder was leaking. |
Originally Posted by briankeery
(Post 1587173270)
Here's another thought... in my research on all of this there was one thread that mentioned a "reaction disc" that could be missing, typically falls out into the booster (http://www.autoshop101.com/forms/brake05.pdf). I did not find one on my old one and none came with the new one, so not sure but if there's supposed to be on in there (goes between end of push rod on PB end) then that would take up some of the missing length? BTW, my old (original) push rod has a disc that's on the rod that has what looks like an integrated seal that move freely on the rod the end that goes into the MC looks like it has a nut behind the rounded end but no threads (looks like adjustable on others I've seen). |
Well I install speed bleeders over the weekend and bled the brakes manually once again, pretty sure there's no air in the lines. I made my own brake fluid recovery jar out a mason jar with a hold in the lid got a 5/16" clear tube from the parts store and could see that all the fluid had a purple hue to it (synthetic) so pretty sure all the old fluid is out.
However, the brake pedal still goes pretty much to the floor but the car stops fine. In fact it has better stopping power than before, kinda throws you forward in the seat. So I'm thinking my old original vacuum booster was shot and not doing anything, just mostly had manual brakes I'm guessing. I know synthetic brake fluid is finicky about allowing air in the system, tried to be careful with the bleeding process. Does anyone know if this is normal pedal operation for power brakes or should the pedal stay fairly high when applying the brakes power or otherwise (had a higher pedal before). Thanks for any advise/feedback, I appreciate the wisdom of those who have gone before... :) |
(Post 1587196071)
Thanks for any advise/feedback, I appreciate the wisdom of those who have gone before... :) I couldn't get the air out of my system after replacing all pads, shoes, and the MC. I flat bedded it to a vette specialty shop, and my trouble (and worries) were over. They knew the car and what to do, and now the brakes operate like when it left the factory. Done. Steve |
Reply to Steve
Originally Posted by Cavu2u
(Post 1587196309)
For peace of mind and the safety of you and those who ride with you, it would be wise to take it to a Corvette shop or reputable brake shop that specializes in these older cars and have them look at it. You've done the best you could, and with the help of all who have chimed in here. You're still not convinced everything is right with the brake system. And it's a damn critical system.
I have a 72' vette that I am changing from manual to power brakes. I purchased my kit from Corvette Central and it too came with an extra push rod in the kit. I was told that the rod can be pulled out of the holder and changed over to the other one. Before knowing this information I tried tugging on that rod and it was not coming out, it turns out that there is an o-ring at the end of the rod that you need to overcome. CC did tell me that the rod installed in the unit as delivered should be fine.
I already have things assembled and I tried bleeding but the brakes are not where they should be. Will bleed again and check how they feel. My bigger problem is that I got my holes mixed up (don't try this at home men) , and installed the booster clevis to the top hole of the brake pedal. So I put the shorter brake switch bracket back on. It took me so long to get the pin in and the cotter pin bent that I just left it. |
Follow-up report:
So I posted here a while back regarding issues I was having with replacing my master cylinder/vacuum booster on my 73 because of a leak I observed between the MC/PB. I had purchased a matched pair from Ecklers to avoid any fitment issues and went through about 2 months of trying to get the brakes bled properly. The problem I had after installing the new MC/PB was that the brake pedal went to the floor after starting the engine. Read all the posting on this and most everyone suggested air in the lines and as I’m using silicone brake fluid made sense to me (former owner switched to silicone). So, long story short I tried the 2 person bleed method, then bought a Motive Pressure bleeder and went through numerous attempts a bleeding to no avail. Ended up replacing all the short hard lines, flex lines; rebuild calipers w/stainless inserts, and distribution/combination block. Always pedal to the floor after starting the engine. So finally called Ecklers, the gal put me on hold to talk to one of their techs, got back on the phone and said the booster was most likely bad. So I said ok then send me a replacement booster, they said I’d have to send the matched set back and reorder. So I said thanks and hung up (sending it back!). Ordered another matched set MC/PB from Napa, got it in the next day (had to paint the PB!) and installed it over this last weekend. I called Motive to confer before starting another round of pressure bleeding. The guy who answered the phone said he was one of the owners and suggested to press the brake pedal a couple of times while keeping about 10 psi in the bleeder. So that’s what I did, saw a lot of air bubbles coming out of RR, must have pressed the brake pedal 8/10 time before no more bubbles. LR didn’t have much air, one of the fronts had more air than the other (don’t remember which one). So I had a nice hard high pedal with the engine off and when I started the engine I finally had a hard pedal without it going to the floor! Eureka! Also, the NAPA MC/PB did not come with a clevis but I had ordered a longer one based on what I had read in another posting that someone suggested so I used it. So now my brake pedal is a little higher than it probably should be but so far not an issue for me when driving. Yes, finally back on the road, missed the whole summer of driving! What a frustrating series of events but glad to be back on the road. BTW, I’m not convinced that the too many air bubble comments I read about has that much value. I’m guessing I still have some air in the lines, albeit not much, or I just got lucky!? What a confidence destroyer/builder learning experience! |
