Accessing the Air Cleaner...
After reading the owners manual and checked You Tube on line I finally decided to go ahead and put a K&N air filter in, removing the stock paper filter. It was a successful venture but you have to disassemble several pieces and remove them before you can access the air filter. Took about twenty minutes to complete the task, and you will need a 7mm socket, with long extension, a blade screwdriver and I believe a size 15 torque screwdriver to get to the airbox.
I highly recommend you watch ZIP's video on You Tube first, as they give you more information that what the owner's manual does. You really need to be careful about the waterlines that runs across the air cleaner to the radiator. Also the right hand lower screw holding the air panel onto the radiator is a little difficult to get too as that small water hose is in the way and you have no play to move it. Have not seen this posted here, so thought I would share my experiences with you...have patience, take your time, don't force anything and you will be all right, not hard, just be careful. :thumbs: |
here it is back in June...I guess you missed it.:D Same conclusions....
http://forums.corvetteforum.com/c7-g...formation.html |
Originally Posted by $$$frumnuttin'
(Post 1587427422)
Can you post a link of where you ordered the filter from? Thanks!
Originally Posted by ssidekickbp
(Post 1587427804)
I put in an airraid synth red filter a few months ago....
Observations: After the first few tanks, no change in mpg No discernible change in volume/sound No discernible change in performance The only advantage for me is it is cleanable..... |
Oiled filters have created issues with the mass air flow sensor.
Originally Posted by Larry/car
(Post 1587430583)
Originally Posted by Glen e
(Post 1587428959)
Observations: After the first few tanks, no change in mpg No discernible change in volume/sound No discernible change in performance The only advantage for me is it is cleanable..... Say it ain't so! :lol: |
Originally Posted by Steve_R
(Post 1587430932)
