clutch recommendation for 650rwhp on LS2 T56
Hey y'all. My trans and diff are being upgraded in my 05 coupe. I thought I would upgrade the clutch at the same time and would appreciate your guidance. I'd like the best of all worlds, factory like pedal feel, sufficient holding power, reliability/durability and preferably no chatter/clutch noise. The car will see occasional track use. A twin disc is fine it meets the above criteria. Please let me know what you are running, how much power your making and any pros/cons.
I have a Centerforce Dyad with a Tick master and am very happy with it.
I only have 540 at the wheels, but the setup will take much more. |
I have a Mcleod RXT, and use their stock weight billet flywheel and have no chatter and stock pedal pressure, and no matter what clutch you choose I highly recommend a Tick Master cylinder. 05 640hp
I've never heard of a Tickmaster Cylinder. What is it and why should I use it?
Originally Posted by JaimeVrod
(Post 1587428432)
http://www.tickperformance.com/tick-...rvette-c6-z06/ |
(Post 1587427214)
Thanks |
Originally Posted by SNL/MonsterClutchCo
(Post 1587428781)
What are your future plans for the car? How do you drive the car weekend warrior, daily driver? Feel free to give us a call if you have any questions.
Thanks I think the Tickmaster cylinder is not something I want to deal with at this time and I'd prefer that the replacement clutch work properly w/ the stock cylinder. For now, I need just enough hp and upgraded drivetrain to get me into the high tens at the 1/4 mile drag strip. |
Mcleod rxt, done. 655rwhp, mid 10s, and 1.5 short times with ease
Lots of choices out there!
Originally Posted by XDemonX
(Post 1587431738)
(Post 1587431738)
Did you have any chatter/noise or balance issues? Are you using the RXT on a LS2, 3, 7 or 9? |
It's an Ls2 car with about 4k on the clutch, stock rear/tranny/short block, and 70k on the car. Clutch has minimal chatter which has dininished as miles increased.
Your goal should definitely be 10s, as my runs were with a 3500ft DA ( Had they been at near or below sea level it would have likely been a very low 10). Hope that helps |
We use the RPS Street Twin 1/2 Carbon clutch kit for anything in the 600-700rwhp range. The driveability and feel of the clutch is amazing, and will definitely hold your power.
We offer the clutch as a kit on our online store with a Tick master cylinder, speed bleeder, and GM slave cylinder for a complete installation. Vengeance Racing - RPS Street Twin 1/2 Carbon clutch kit |
Just tell RPM exactly what you want out of the clutch; stock feel, no chatter, whatever, and they will know which one to put in. It may not be maximum hold with above requirements
