78 C3 Oil pump knock??
Breaking in a 350 CID 300hp, re-build.....I have 3 - 4 knocks then pause and repeat 3-4 knocks the pause, sound coming from oil pump area of motor. used one of those stethoscope to listen, sound coming from oil pump area loudest near oil filter and oil pan around oil pump.
the rest of the motor sounds like it should. oil pressure @ 2K 50lbs 35K 70-75lbs gauge reads pressure holds, when back 950 knock, knock, knock some times loud sometimes not. I used the pump from the 350 I replaced.... Has any one ever had a oil pump knock?? if so what did you do? I think it needs to be replaced? |
cannt be from distributor since it connects to pump?
If it's an automatic, check the flywheel for cracks, loose converter bolts or loose flywheel bolts.
So many things can cause that kind of noise. None of them are good. I agree with bashcraft for starters. If that checks out, I would have to think that you have a bad rod or main bearing. Automatic or manual? The thrust bearing clearance could cause the crank to "walk" in the saddles but that would be worse with a manual.. Is there any movement at the front, such as the balancer? Can you see it moving in and out ever so slightly at idle?
I was given a forged crank when I was building my engine that came from a truck. I was really good looking until I started looking at the thrust bearing surface. There was significant wear from pushing the clutch in over the years wearing the crank badly. So I didn't use it. |
It's a manual trans. I go out and run it. listen, come back in and think it through..
I have to rule out pump, dose not make since. it sounds rhythmic, possible end caps??? the knocking dose not stop when using clutch..... Trying to contact builder, and have a mechanic coming over to test AC vac, to see if it holds pressure. it's a new system never has been charged, so I want to know if it will hold, but now..I have him wait on the charging and look at the knock.......I am hoping minor problem, but expecting major...pull motor take it back to builder..I do not know .???? |
Originally Posted by MelWff
(Post 1587434889)
Guess I wasnt clear
Originally Posted by Douglas Brown
(Post 1587437133)
Agreed
Originally Posted by bashcraft
(Post 1587435511)
Thanks for the input. |
(Post 1587437158)
What i was asking was are you sure the noise isnt from the distributor?
The further away from that area I go the lower the noise |
Originally Posted by CaseyJones
(Post 1587435636)
I was given a forged crank when I was building my engine that came from a truck. I was really good looking until I started looking at the thrust bearing surface. There was significant wear from pushing the clutch in over the years wearing the crank badly. So I didn't use it. Do not see any movement at he front end of the crank. This was built for me at a engine/motor rebuilder in St George, Ut. Not saying it was a bad job but mechanical things do not always go as planned. |
After I talk to these guys I post results.
(Post 1587437158)
thanks |
Up date on knocking.....not pump, found metal flakes in valley....motor goes back to builder...
https://cimg0.ibsrv.net/gimg/www.cor...0edb148934.jpg |
Update: turns out to be flat cam...Now we deal with COMP CAMS warranty.
