Rear hatch not opening/closing reliably
1 Attachment(s)
Hi all, I hope someone can help me out with this.
I have a 2009 C6 Coupe, and have had it for 2 years. Over the last year or so, I've found the rear hatch is getting more and more difficult to open or close as time passes. I have read many forum topics about similar issues, but nothing quite like this, and no ideas as to what it might be, so far. Here are the symptoms: 1) When I attempt to open the rear hatch, with either the key fob, the interior button or the exterior button by the rear registration plate, I get the same behaviour: Each time I press the button, I hear a mechanical noise, and in about 4 out of 5 cases, nothing else happens. If I am lucky, the hatch will open normally. (From this I would surmise that it's not an electrical problem - relay, fuse etc as all methods produce the same result, and I always hear a mechanical noise when I hit the button) 2) If I press down on the hatch prior to pressing the button, it doesn't appear to make any difference. 3) If I have a door open while pressing the button, it doesn't help either. 4) If I use the key to manually open the hatch, it opens successfully every time. 5) I also have a problem when I try to close the hatch. If I press the hatch down gently, it no longer engages the automatic grab-and-close mechanism, which it used to a couple of years ago. I have to push down hard, and wait for the mechanism to click before I am sure that it is closed. 6) If I try dropping the hatch shut, from a height of 6" or so, it does not engage the auto-grab-and-close-thingy either, I have to push it shut manually. 7) One thing I am wondering. When I am inside the car, with the hatch down but not closed, and I look towards the rear of the car at the hatch striker, it seems to be a long way towards the right of the hatch closing mechanism - I would have expected it to be around about the centre of the mechanism. Is this normal?? (Refer attached image) 8) Also, when the hatch is closed, the middle of the hatch seems to be raised somewhat - maybe 3 or 4 mm (1/8 inch)? Is this normal? So, I'm wondering if the rear hatch is misaligned - would someone be able to compare what I see with a C6 having a working rear hatch? (Photo attached) My service guy is suggesting I replace the locking mechanism, but I'm hoping I don't need to do anything so drastic (and expensive). Any help or ideas appreciated ! |
Originally Posted by Steve.NZ
(Post 1587433003)
I have a 2009 C6 Coupe, and have had it for 2 years. Over the last year or so, I've found the rear hatch is getting more and more difficult to open or close as time passes. I have read many forum topics about similar issues, but nothing quite like this, and no ideas as to what it might be, so far. Here are the symptoms: 1) When I attempt to open the rear hatch, with either the key fob, the interior button or the exterior button by the rear registration plate, I get the same behaviour: Each time I press the button, I hear a mechanical noise, and in about 4 out of 5 cases, nothing else happens. If I am lucky, the hatch will open normally. (From this I would surmise that it's not an electrical problem - relay, fuse etc as all methods produce the same result, and I always hear a mechanical noise when I hit the button) 2) If I press down on the hatch prior to pressing the button, it doesn't appear to make any difference. 3) If I have a door open while pressing the button, it doesn't help either. 4) If I use the key to manually open the hatch, it opens successfully every time. 5) I also have a problem when I try to close the hatch. If I press the hatch down gently, it no longer engages the automatic grab-and-close mechanism, which it used to a couple of years ago. I have to push down hard, and wait for the mechanism to click before I am sure that it is closed. 6) If I try dropping the hatch shut, from a height of 6" or so, it does not engage the auto-grab-and-close-thingy either, I have to push it shut manually. 7) One thing I am wondering. When I am inside the car, with the hatch down but not closed, and I look towards the rear of the car at the hatch striker, it seems to be a long way towards the right of the hatch closing mechanism - I would have expected it to be around about the centre of the mechanism. Is this normal?? (Refer attached image) 8) Also, when the hatch is closed, the middle of the hatch seems to be raised somewhat - maybe 3 or 4 mm (1/8 inch)? Is this normal? So, I'm wondering if the rear hatch is misaligned - would someone be able to compare what I see with a C6 having a working rear hatch? (Photo attached) My service guy is suggesting I replace the locking mechanism, but I'm hoping I don't need to do anything so drastic (and expensive). Any help or ideas appreciated ! put up with it or replace the latch assembly :ack: Mine is on the second one now and it is acting up again :ack: it isn't hard to replace and you can get one from Gene Culley forum vendor http://www.gmpartshouse.com/index.php |
Originally Posted by ErnieN85
(Post 1587434371)
you have two choices
put up with it or replace the latch assembly :ack: Mine is on the second one now and it is acting up again :ack: it isn't hard to replace and you can get one from Gene Culley forum vendor http://www.gmpartshouse.com/index.php https://cimg2.ibsrv.net/gimg/www.cor...8b288eb737.jpg |
Try adjusting the striker. A quick comparison of the screw to striker distance in the two previous pics makes it obvious there is a large adjustment available.
(Post 1587434371)
put up with it or replace the latch assembly :ack: Mine is on the second one now and it is acting up again :ack: it isn't hard to replace and you can get one from Gene Culley forum vendor http://www.gmpartshouse.com/index.php I's coming to the same conclusion myself. I'll see how easy it is for me to source one at a reasonable price (I live in New Zealand, so international shipping will add to the cost). It's looking more likely that I'll just have to put up with it :( |
Originally Posted by EVRose
(Post 1587435375)
:iagree: It shouldn't be that hard to replace yourself. I tried to get a pic of mine. It looks like you have a plastic surround piece on the opening. Mine doesn't have that but it looks like it drops in pretty close to center.
It seems that the latch mechanism is behind the carpet, so It seems hard to tell whether the striker is central in the latch mechanism opening as the opening itself is obscured by carpet? |
Originally Posted by HOXXOH
(Post 1587436275)
