Hit the Motherload of Warning Lights!
First I get a flat tire warning that turned out to be for the wrong tire (all four sensors are set for the wrong tires). Then, on the way to Texas, I get "service antilock brakes", "service active handling", and "service traction control" lights on mt dash. The latest problem is a piece of interior trim has broken.
My 2009 Z51 Coupe was trouble free for four years! Taking it to the dealer on Thursday. Thankful for the warranty! Rant off. BobD |
I am going to save you and your tech a lot of trouble. The problem is in the High Speed Data Bus connectors (big blue connectors) that are in the passengers footwell. You have several pins that are loose. I have my car in the shop right now for the same reason. They are repinning both connectors.....
I am sure your gages stoped working and the car told you it was low on fuel and service engine soon... but it was running fine... If you turned it off all would be well for days. Then poof it all starts up again. |
:iagree:
My first thought too. Those big blue connectors can trigger all sorts of warnings/failures when the connections become intermittent. Good luck with your Dealer. |
That is great information to know. Thanks for passing along
Originally Posted by 08 ATOMIC-Z
(Post 1587502303)
I am sure your gages stoped working and the car told you it was low on fuel and service engine soon... but it was running fine... If you turned it off all would be well for days. Then poof it all starts up again. Most often just pulling the contacts apart, then pushing them together again, perhaps a dozen or so times will cause a "wiping" action between the contacts. This will clean them, and you're good to go again for another few years. :cheers: |
(Post 1587502303)
(Post 1587502303)
I had all the same lights and turned out to be EBCM, electronic brake control module...
Originally Posted by psp6158
(Post 1587504717)
Originally Posted by FiremanC6
(Post 1587502106)
My 2009 Z51 Coupe was trouble free for four years! Taking it to the dealer on Thursday. Thankful for the warranty! Rant off. BobD Sincere apologies to read about your warning lights illuminating. Although I understand your displeasure, it's great that you've proactively reached out to your dealer for an official diagnosis. Feel free to keep us posted on the process if possible, and message me privately if additional assistance is needed. William R. Chevrolet Customer Care |
I got "service antilock brakes", "service active handling", and "service traction control" lights but I also got ICE Possible.
There seams be a lot of this going around, mine only happens during the first acceleration until today 4 times during accelerating, but I couldn't get it to act up after that. |
How's your battery?
Do you have telescoping steering column? |
Originally Posted by Legal Alien
(Post 1587627534)
How's your battery?
Do you have telescoping steering column? This ICE possible message I'm receiving along with the traction ones make me think loose or corroded pins in my EBCM. Only happen when get above 30 and then quits usually one hick up but had 4 of them the last time out. Then the next 20 miles no issues. I also it's a 2008 which is a Delphi part, the next year Corvette changed to another Company. |
Genuine question - How does the 'ice possible' message fit in? I was under the impression that was just based on OAT?
All the others I can fathom a link but how does that fit in? That would lead me more down the idea of a voltage/connector/ground issue. |
(Post 1587627765)
So you have the original battery?
Originally Posted by Don-Vette
(Post 1587629659)
Just put a meter on it and it's 12.1 volts. I haven't started it in 2 days |
I had the Service Active Handling, Service Traction Control, Service Antilock Brakes errors show up on my DIC as well. I have an '07 coupe. I had just put on front brake spindle ducts and I was sure it had to be a ABS connector... I pulled the wheels and re-checked. All was fine. Cleaned and re-seated anyway. Problem stayed intermittently.
Finally, I reset my personal preferences so that the steering column would NOT retract on exit. I programmed it so the steering column never moves. PROBLEM SOLVED. There's a small rake-like connector for the steering pos sensor that is known to cause these errors as well. I'm not saying that re-seating the Big Blue connectors (Data Bus) is a bad idea. It's a good idea, but don't discount other possible sensor connections as well. Too much damn computer control in these cars, but when it saves your bacon, you're glad it's there! |
(Post 1587502106)
My 2009 Z51 Coupe was trouble free for four years! Taking it to the dealer on Thursday. Thankful for the warranty! Rant off. BobD BobD |
