'02 Z06 'OH JAM' 10.99 @131.4 cam + 150 N2O - 1.9 60 ft - 2100 DA
3 Attachment(s)
First time out to the track with my car on a good tire and I am thrilled with the results! I have never even ran an 11 in my life. Last time out I ran 12.3 at 119 on street tires, best times last Friday were 11.8 @ 118.32 mph & 10.997 @ 131.38 mph.
'02 Z06 - 120K miles -stock bottom end, untouched heads, stock intake -234/240 .605/.617 @ 111 LSA -Varraram intake -Longtube headers & Corsa Xtreme -Built T56 & MGW shifter -DTE trans/dif brace -PFADT anti-wheel hop trans mount -full stock suspension (slammed) -CCW 17x8 & 16x10 w/ 26x11.5x16 MT ET street @ 11.5 PSI -Car weighed 3330 with me in it & almost 1/4 tank of gas (I weight 200) -DA was 2095 per Drag times.com attached a couple pics and time slips & Video's below: |
very nice surreal that 60ft and still a 10 second pass:thumbs:
what injectors are you running?! |
Good run and even better pictures :cheers:
Originally Posted by pit-man
(Post 1592752143)
Forgot to report back I ran 10.33 @ 135 at SGMP in December with the car, no changes other than track and track prep. cut a 1.51 60 ft.
-Gibson |
How did you run so consistent on your 60' LOL
That bottom pic is badass with that tire wrinkle! |
Congrats on the 10 second pass. :thumbs:
However, I would caution you about running a non-skinny radial tire up front. The car may get loose. |
How will running a wide tire up front make it get loose? I've never heard that before. Great runs!
Originally Posted by stratsRR
(Post 1594123605)
The pics in the original post were when I ran it for the first time (my skinny's had an air psi leak so I couldnt use them).. although I did not have any issues with the full size radial front at that track day, I switched to a skinny front with a bias ply tire after that.
