Finally built my own car! lots of attention to detail here
10 Attachment(s)
well after a long time of gathering parts and saving up it was finally time to turn my own car into a half mile monster (hopefully) I didn't take a picture of everything but this is the breakdown of it all.
LSA block with custom wiseco pistons **coated skirts, upgraded pins, vertical gas ported, tool steel rings 11:2 compression** LS9 Rods w/ ARP 2000 rod bolts LS9 crank w/ arp mains held down with new age 625 head studs Advanced induction ported LS9 heads LS3 intake manifold LS2 throttle body Mechman billet alternator Kooks 2'' longtubes, 3'' off road mid, b&b fusion 3'' axle back ECS 10 rib kit with novi 2200R 2.75 one off griptec pulley with 10% overdriven lower **revving to 7500** should be 23-24 psi A&A flip drive ECS big intercooler w/ dual bypass valves Wastegate setup with boost by gear Fore innovations triple walbro 450 fuel pump setup with FIC 1650CC injectors on E98 fuel Viking drag coil overs front and rear LG drag rear control amrs LG drag rear sway bar LG drag spindles RPM level 7 tr6060 w/ ZR1 5/6th RPM level 6 diff 3.42 rear gears RPS triple clutch Driveshaft shop torque tube w/ coupler delete Driveshaft shop level 5 axles All new suspension parts everywhere, all new accessories as it all had 107k on it Dewitts cut down radiator w/ 17'' brushless fan weld S77 18x6 fronts and 15x12 rears (beadlocked) C7 shifter Hoosier diff mount DTE trans/diff brace ABS delete, evap delete, lots of misc non needed stuff deleted, still has ac and powersteering though! Painted engine bay carlyle racing lugs possibly doing a drag wing and chute too I'm sure there is so much i'm forgetting but that's the bulk of it. Video is headers w/ open x pipe as axle back wasn't on yet. |
Congrats, can't wait to see how it performs.
awesome, I've been looking to get the viking coilovers soon also. Curious if you guys log any alternator drop with the mechman at 1/2 mile or on dyno too.
Cool build. Thanks for sharing.
What are your goals for the car? |
Originally Posted by Capthuff
(Post 1593824188)
Very nice.
awesome car:thumbs:
That's a good looking engine bay. How did you get everything looking so new?
Man that thing is clean! really like that Transmission setup.
Looks Killer!
Originally Posted by 540i 6spd
(Post 1593826956)
Very nice.
(Post 1593827039)
awesome car:thumbs:
Originally Posted by etekberg
(Post 1593827113)
Originally Posted by billetproof97'
(Post 1593827215)
Originally Posted by BLOWNBLUEZ06@RKTPerformance
(Post 1593827266)
Looks Killer!
looks awesome looking foward to see results :)
best of luck |
Nice.
great build :flag:
:thumbs: Nice :cool:
:cheers: |
forgot to post my dyno video. Car will be going back on with a meth kit as I was close to maxing out the injectors and iat's were a little higher than I want, timing is still semi low so power will go up some from here. But still 1048 rwhp 915 rwtq. This thing with the compression makes a tad over 700 rwtq by 4k rpms!! Absolute blast to drive and really drives like a nice bolt on w/ a small cam car. With the meth kit thinking it'll land around 1130-1150 rwhp.
Very Nice! Congrats!
with that much power you might consider going direct port with the alchy
on Mr Le's F1X car he was putting down over 1200 and found the alchy was "carrying to the back" of the manifold and running the back cyl a bit too rich and the front a bit too lean (EGT monitoring on all 8) the egt variance was over 200 deg which showed poor distribution which makes sense as the intake is designed for dry flow after going direct port, the car picked up and ran much smoother and the variation dropped down to less the 50 deg difference you could then "tune the pills" a bit to even that out if needed based on airflow variations in the manifold. I'm going to give it a try on my next build but may use another set of injectors and staged fueling rather than just nozzles so I can get help from the wide band tuning and EGTs ECS makes a nice setup, not sure of the cost, but at those HP levels I think it would help. boost a muv!!!:thumbs: |
WOW, Very cool build, and GREAT power!!:thumbs:
I'm also running one of your one off custom pulleys, works pretty darn good... |
