Need 454 accessory brackets
Hello all. I am collecting parts for my 454 swap and need accessory brackets for a corvette. This is a driver and the parts will probably be powder coated, so barrett jackson quality is not required.
Much thanks! |
I am doing the same thing and got my brackets from another member.
When you go to buy the pulleys. The water pump one is over $200 new and about the same used. They are like gold. I found this pulley to be the same and it works. https://www.corvetteforum.com/forums...for-cheap.html |
