1956 Powerglide leaking
I have a leak it appears to be where the kickdown shaft comes out of the side plate. Does anyone have a diagram of this before I start the process?
Thanks |
Originally Posted by GasWorksGarage
(Post 1594097950)
Thanks One thing I have learned about the Powerglide is that there is a check valve that prevents fluid in the torque converter from draining back into the pan when the car is parked. If this check valve leaks, the fluid level in the pan will rise when the car is parked, and eventually fluid will leak out around the kickdown shaft and the shifter shaft. Fixing this problem requires fixing the leaky check valve. A work-around is to start the car periodically to push fluid back into the torque converter. If you suspect this is the problem, just check the fluid level with the dipstick, *before* you start the engine. If the level is unusually high, it's probably because of drain-back from the torque converter. |
I believe most cast iron Powerglides will leak if stored for a month or more.
If you start it from time to time and run through the gears it typically will not leak until it is again stored for a month or more. |
