-   C1 & C2 Corvettes (https://www.corvetteforum.com/forums/c1-and-c2-corvettes-4/)
-   -   testing gauge cluster Qs? (https://www.corvetteforum.com/forums/c1-and-c2-corvettes/3945579-testing-gauge-cluster-qs.html)
20round 02-17-2017 06:14 AM
hi there again, I have my gauge cluster apart cleaning things.. what is a good way to test the tach and speedo to make sure they are working properly and lubed. I know there can be issues with both these running loud and clicking? they look perfect so I am hoping just a proper dusting will do with what ever lube may need to be on them..also a safe and proper way too test the gas, temp, and amp. I can hook the psi gauge to the engine in the chassis. I tried using the search engine here but I must be stupid:hide: cuz I could not get anything I was looking for to come up. thanks everyone troy:thumbs:
dkleather 02-17-2017 08:29 AM
I've had much better luck Googleing whatever information you're trying to find on this forum. Go to your Google bar and Enter "C2 Corvette calibrate speedometer" or whatever you want to find. I think you'll have better luck getting the info you want. :thumbs:
20round 02-17-2017 11:03 AM
your probably right it seems to show up faster on there..thanks troy:thumbs:
buns 02-17-2017 02:03 PM
1 Attachment(s)
https://www.corvetteforum.com/forums...eedometer.html
