Cam only C5 Z06 makes 440 SAE on two different dyno's
STD(standard uncorrected) numbers were 452/440:willy: Temp was around 67 degrees with 39% humidity(looow for the deep south)
Cars mods: Fresh engine with 400 miles on it. If not noted below, it's stock or stock replacement: Mahle pistons Eagle I beam rods Heads milled to 59CC for 11 to 1 compression VMax CNC ported throttle body PAC 1218X valve springs 7.350 restricted push rods from Schwanke engines LG Superpro headers and catless X pipe Vararam intake Cam is from Geoff@EPS(Engine Power Systems) 228/236@.050, .604/.604 lift, LSA is 111+1 Car is a ball to drive, it runs hard. Idle vid, first start untuned. I think I put my finger over the mic on the phone for a sec is why it sounded muffled for a few seconds Graph, hope it shows up well for you guys...because DAMN it's purty lol. https://cimg7.ibsrv.net/gimg/www.cor...f95a67a463.jpg https://cimg9.ibsrv.net/gimg/www.cor...4e556e431d.jpg |
I put it on a different dyno today because I thought the numbers were a tad high, I was proven wrong.
The first sheet (440/430) was on a new Dynojet that the RPM was taken from the drum itself because the inductive RPM pickup on the #1 plug was not working well. Today I put it on an older dyno that pulled RPM from the #1 plug, torque dropped but the power was still there. https://cimg4.ibsrv.net/gimg/www.cor...f72e61e2e1.jpg |
Originally Posted by FASTFATBOY
(Post 1594271231)
The first sheet (440/430) was on a new Dynojet that the RPM was taken from the drum itself because the inductive RPM pickup on the #1 plug was not working well. Today I put it on an older dyno that pulled RPM from the #1 plug, torque dropped but the power was still there. https://cimg4.ibsrv.net/gimg/www.cor...f72e61e2e1.jpg Idle sounds perfect!! Thanks for sharing. |
Cam only is head work and a built bottom end now?
Originally Posted by SBCGENII
(Post 1594281473)
I basically did a stock rebuild with a $300 set of rods and a good piston, it's nothing special for sure. |
Nice numbers non the less ... head work or not...
but the heads are touched so it's not cam only ha .... don't really matter .. badass ride! Congrats |
So milling the heads, new pistones and rods, long tube headers and CAI is cam only?
I think those numbers are pretty much in the ball park. I have similar mods and similar numbers with a smaller cam. |
Originally Posted by warren s
(Post 1594281597)
I think those numbers are pretty much in the ball park. I have similar mods and similar numbers with a smaller cam. Nice power FASTFATBOY. 450 Is pretty good with stock ports, but that cam and boltons probably won't make the same power if you installed it in a stock motor. Different rings and hone could pickup a lot by themselves. |
(Post 1594282014)
Cam only is slang for all boltons plus camshaft. So one should assume the car has all boltons.
Like Jumbo Shrimp. |
(Post 1594282035)
Tharts a new one on me. Guess I need to get out more.....
(Post 1594281473)
(Post 1594282069)
Just slang from the old fast lists on LS1Tech. I think they have similar lists on here.
This has been known for YEAAARRRS. Most built the car in stages... 1-"bolt ons"=headers, no cats, intake, throttle body, under drive pulley and even bigger rocker arms. Sometimes even a FAST intake. 2- "Cam only"=The above plus a cam 3- "Head/cam"=the above plus ported heads This has been known since Fred Flintstone traded for his first LS in 1997 :rofl: |
A "built" bottom end contributes to power? I built a fresh engine with some better parts for road course duty.
People make 1060rwhp with a stock bottom end 4.8, but somehow I make more power with a cheap ass $300 set of rods and a good piston? Come on guys, it has one more cubic inch than it had from GM. I put rods in it because it costs $250 to resize stock rods and put in ARP bolts. The pistons were a no brainer, the car even has a stock redline(6500)....not like I'm spinning it to the moon to make those numbers. Stock clutch(It's new, I guess I gained from that?), pullies, intake, injectors, Ti catback, rocker arms, head ports So you guys keep picking the "cam of the week" to make 420rwhp and 380 and torque and I'll keep doing my thing. |
I'd say it certainly would be considered cam only. The short block, built for a street/roadrace application is no slicker that's stock. The good rods/pistons are really not worth anything and may be a tick heavier. Milling the heads to a. Umber that is still within GM's serviceability window isn't going to do much. They're not angle milled .120, they're probably cut .028-.032. Which any shop would do if you had a set of factory heads "freshened", especially if it had a blown head gasket issue. At most he can now run less timing and needs more fuel. The difference it makes is within the margin of error of why the dyno reads.
Some folks LK's buy into the "so and so big name tuner makes the most power with this proprietary camshaft" and can't stand it when someone with some engine knowledge beats the "pros" at their game......for a far cry less money in most cases. Rock on FASTFATBOY, wave at the haters in the mirror. and take this from someone who races NHRA stock eliminator and knows what stock is and what actual benefits individual mods make. |
Something else I just thought of. Most aftermarket pistons have a valve relief. Did yours? How much was it cc wise?
most are 4-5cc. GM nominally calls the 243 head a 64cc chamber. So if you milled to 59cc and your pistons have a 4cc valve relief you managed a net compression increase equal to 1cc? Yea that's the explaination for the extra power 🙄🙄🙄🙄🙄🙄🙄🙄 Buncha check writers. |
(Post 1594282512)
This^^
This has been known for YEAAARRRS. Most built the car in stages... 1-"bolt ons"=headers, no cats, intake, throttle body, under drive pulley and even bigger rocker arms. Sometimes even a FAST intake. 2- "Cam only"=The above plus a cam 3- "Head/cam"=the above plus ported heads This has been known since Fred Flintstone traded for his first LS in 1997 :rofl: Take a look at the for sale sections for C5s and C6s - Cars are advertised as H/C/I.... Heads, cam and intake and exhaust. |
(Post 1594283723)
For years huh? If you say so.....
Originally Posted by vetteman9368
(Post 1594282775)
I absolutely can, I do. But I don't go looking for it road race applications and neither does anyone with any sense. It's like building an offshore powerboat motor. Bulletproof matters more than raw numbers. Keep writing checks and I'll keep making horsepower. PS look up the rules for NHRA stock eliminator, then look up the performance. I'll give the short version. Stock heads, stock lift cam, blueprinted short block (better parts, stock dimensions), no power adders. The fastest C5 LS1 is a nine second car. Like I said, keep writing checks.
Nice NUMBERS! I love it when people argue over dyno numbers. There hasn't been this much action around here since the season ended. :lol: My impression of a dyno is that they are a "tuning device" and can be used to see what the actual gain of the mods were/are before and after the tune and the addition of a supporting mod.
I'd love to see what it runs in the quarter mile especially what it's mph is. I read it's a road race car and would probably not see any quarter mile tracks but in case you ever do please stop by the sticky at the top of the page and see how you compare. We would be in the same category "Internal Engine Modifications - Head/cam -> 346 " with you putting down about as much rwhp as I do. Unfortunately we do not have a "cam only category". Actually, you have higher numbers but what the heck, they are only numbers. The real number to me is how well it 60 foots and what it will run in the 1/4 or 1/2 mile. The term cam only has been tossed around for a long time and seems used loosely used but as we all know adding just a cam is a waste without supporting mods. What do I know, I wrote the check because I'm dumb and stupid for not perusing a career in auto mechanics. :cry |
