Stock injector size for 2002 LS-1 and Z06?
What size are the stock injectors on the a stock 2002 LS-1 and Z06? There is a set on e-bay that the seller claims are 2002 stock Corvette 30lb. injectors. I used the buy-it now and want to make sure he is correct before I send the payment.
Thanks,Michael :confused: |
Re: Stock injector size for 2002 LS-1 and Z06? (meyre1)
If you did the BUY IT NOW you own them you should check on items before you BID Read the Ebay, Disclaimer........... :yesnod:
Excerpts from:
http://www.vetteguru.com/mods/howto/ Not aware of any changes for 2002. 97-98 = 28.4 lbs/hr 80% duty cycle rating: 45.44 Crank HP x 8 = 363.52 Crank HP 100% duty cycle rating: 56.8 Crank HP x 8 = 454.4 Crank HP 99-2001 = 26.4 lbs/hr 80% duty cycle rating: 42.24 Crank HP x 8 = 337.92 Crank HP 100% duty cycle rating: 52.8 Crank HP x 8 = 422.4 Crank HP Z06 = 28.2 lbs/hr 80% duty cycle rating: 45.12 Crank HP x 8 = 360.96 Crank HP 100% duty cycle rating: 56.4 Crank HP x 8 = 451.2 Crank HP |
Re: Stock injector size for 2002 LS-1 and Z06? (2000 Pewter Hardtop)
Pewter Hard Top, I do not think you are committed to buying the item if the seller misrepresents it. I used the buy it now because it was $100 buy it not for 2002 Corvette 30lb stock injectors with 7 miles on them. If he is correct that is a great deal. What are the parts numbers for the stock ls1 and Z06 injectors?
[Modified by meyre1, 4:42 PM 12/22/2002] |
ttt
it is prudent to know what you are buying, before you bid. it is up to you not to be a victim, reduce the possibility of ripoff, fraud or just buying the wrong part and blaming the wrong person. you should know what you need. that is what im trying to tell you. :cheers:
