Disable Seat Belt Chime?
Old 06-28-2005, 06:08 AM
ucla81
ucla81's Avatar
Default Disable Seat Belt Chime?
Does anyone know the sequence to disable the seat belt warning chime? My other car had instructions in the owners manual; I cannot find the sequence in my C6 manual. Help! Thanks...
Old 06-28-2005, 06:45 AM
stanleyp
stanleyp's Avatar
You can't (it's integral with the computer). Just cut a pc. of rigid plastic the same shape as the seat belt clip and slip it in. That will stop the nagging.
Old 06-28-2005, 09:13 AM
GGWOODY
GGWOODY's Avatar
Location: Buena Park, CA I seem to have left my electrolytes with your daughter
why?
if you're using a 5-point just run a piece of flashing with a debburred flange in there.
Old 06-28-2005, 10:13 AM
rudybeet
rudybeet's Avatar
You can easily disable it by buckling up, dude.
Old 06-28-2005, 10:14 AM
VET4LES
VET4LES's Avatar
Old 06-28-2005, 11:07 AM
ucla81
ucla81's Avatar
"Dude"? At a drive-in movie the other night with the engine running for a/c, (or for heat in winter), I really don't want to listen to the seat belt chime.
Thanks for your sarcastic and unproductive assuming replies.
Old 06-28-2005, 11:24 AM
rudybeet
rudybeet's Avatar
A movie theater or DVD rental should also clear up the problem, dude.
Old 06-28-2005, 11:34 AM
CAU-LLC
CAU-LLC's Avatar
The right size lugage tag will work! Just fit in the slot and he or she (depending on gender of Vette) thinks it's buckled.
Old 06-28-2005, 12:36 PM
AMF
AMF's Avatar
Buckle your seatbelt with the belt behind the seatback. That will take care of the problem.
Old 06-28-2005, 12:37 PM
mforman42
mforman42's Avatar
I'm confused. My seat belt chime doesn't sound with the engine running and the handbrake on, although the light remains lit. Is my car broken perhaps?
Go Bruins!
Old 06-28-2005, 12:43 PM
jazzlove
jazzlove's Avatar
Location: San Antonio Texas - Any sufficiently advanced technology is indistinguishable from magic
You're welcome....
Drive-In movie...? Wow! Haven't been to one of those in 35 years, in fact, I didn't know that any still existed. I thought they'd all gone the way of the pay phone... Man, that brings back some great memories! Can't say that I ever paid that much attention to the movie though! :o
Old 06-28-2005, 02:29 PM
juiceman03070
Support Corvetteforum!
juiceman03070's Avatar
St. Jude Donor '08
I am waiting patiently for an informed reply.....Perhaps the joksters would be better off in the OFF TOPIC section
Old 06-28-2005, 02:33 PM
doccoch
doccoch's Avatar
Please consider how un-helpful this kind of comment is. If you don't have a real answer or advise, maybe just go to the next thread?????
Old 06-28-2005, 02:43 PM
HOFFIE
HOFFIE's Avatar
buckle it before you get in,so it sits behind you..
Old 06-28-2005, 04:01 PM
C6Harley
C6Harley's Avatar
In my ex girlfriends focus, you could disable it by:
buckle and unbuckle the belt 3 times, turn the headlights on, then off. then the belt light would flash on the dash 3 times. Then you buckle and unbuckle the belt 1 more time within 5 seconds.
Oh and you have to do the whole thing in less than 60 seconds. It was the craziest thing I think anyone has ever designed.
I wish I could help on the C6, but I don't know.
Old 06-28-2005, 04:38 PM
rudybeet
rudybeet's Avatar
Lighten up. A little humor is fine, and he did not indicate in his original post WHY he wanted to disable it. Sorry, but IMHO, if you don't wear the belt when driving, you shouldn't be on the road. Plus, it's illegal in most states. So I think my advice was right on the money.
Old 06-28-2005, 04:43 PM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
I've got a copy of the owner's manual on my hard drive and I have done a search for both "seat belt" and "safety belt." Actually, "seat belt" only oocurs once in the manual. But for the 30-40 occurrences of "safety belt", I could not find anything that tells you how to silence the reminder chime.
My C6 will only ding the chime about 5 times, but it will leave the light illuminated on the dash. This is a special case where the vehicle was never put in motion.
EDIT: Here's the section of the manual that makes me think my car is working like the manual says.
Safety Belt Reminder Light
When the ignition is turned on, a chime will be provided
for several seconds to remind people to buckle their
safety belts. The driver safety belt light will also be
provided and stay on for several seconds, then it will flash
for several more.
Makes me think it should only stay on for a few seconds. Of course, it might be annoying if you have to do it several times while at the drive-in (or wherever).
To Disable Seat Belt Chime?
Ares & Randy
Ares & Randy's Avatar
Go Bruins!
Ok, I just came back from testing this. I got in the car, closed the door, MN6 in reverse, emergency brake on, started it up, the seat belt chimed for maybe 5 secs, then stopped, shifted to neutral, and idled with the emergency brake on. The seat belt warning light kept flashing though.
Whenever I went to the drive-in (long ago) I also had a car with a bench seat. :o
Old 06-28-2005, 05:49 PM
mikeyc6
mikeyc6's Avatar
So far, I like the suggestion about buckling the seatbelt with the belt behind the seatback: then you don't have to sit with the belt riding up your back as you move around in the seat.
Another suggestion, couldn't you just buy an extra latch (male end I mean) through GM and stick that in the receptacle? Of course, with any solution like this you have to be careful that you remember to relatch the seatbelt properly before you drive off. Any of these solutions are just inviting people to drive off and forget to put the seatbelt back on properly without realizing it.
FWIW, mine doesn't beep if I'm sitting still. It only dings if I'm moving. The light is another story.
Mike
Old 06-28-2005, 09:01 PM
Rob4092xx
Rob4092xx's Avatar
I agree 100%!
Why post a stupid response to a serious question!
Quick Reply: Disable Seat Belt Chime?
