Skip Shift Eliminator for the C6....
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Now at Southern Car Parts....
Do you hate the 1-4 skip shift installed on the C6 Manual Transmission? This little device will eliminate that annoying issue.
This kit will allow you to disable the Computer Aided Gear Selection (CAGS) feature of your C5 Corvette's 6-speed gearbox. This kit uses genuine Delphi Packard Electric Systems division connectors, plugs and seals to protect your wiring harness and CAGS solenoid to allow you to re-connect the harness for full CAGS function, if you so desire. This kit is designed for use on both the standard MN6 Corvette's 6-speed gearbox and also the M12 Z06 Corvette's 6-speed gearbox. No permanent modifications are required to install this product.
Takes 5 mins to install and is easily reversible.
Each Kit comes with complete installation instructions.
NOTE: This kit will prevent the CAGS solenoid from engaging but the "1 to 4" light on the dash will still illuminate when skip shift conditions are met.
Still have some in stock.....free shipping...
Order today... Ship Today
Click here to order.
http://www.southerncarparts.com/prod...roducts_id=104
Jim
Jim
Supporting Vendor
Thanks,
Jim
St. Jude Donor '08
Shift Eliminator
This product takes ten minutes to install, including backing up on the ramps!! This is a great product, you'll be glad you bought it!!
