CA legal headers w/air injection emission ports
Old 10-19-2008, 08:45 AM
merrell.a
merrell.a's Avatar
Default CA legal headers w/air injection emission ports
Does anyone know who sells headers with the smog air injection for an 81, and CA legal to pass the emissions testing. I know Hedman sells headers where you have to drill the holes in the headers to install/weld the smog injection kit. Anyone sell them already pre made?
Old 10-19-2008, 11:09 AM
LIQUIDDRAGON
LIQUIDDRAGON's Avatar
i got a set from here for my 76 and they make them for all years to replace the factory exhaust manifolds woth NO modifications. they are expensive but the quality reflects the price. the customer service is great also and everyone that i spoke to was very nice and knowledgeable.
http://www.vetteheaders.com/servlet/...art=9&total=13
Mike
clevan barclay (10-25-2016)
Old 10-19-2008, 11:54 AM
birdsmith
birdsmith's Avatar
You might also look up J. Bittle (JBA) in San Diego.....he used to do exclusively Ford stuff but started branching out several years ago and his headers are some of the best pieces out there; very nice. He even had a '69 427 vert parked in front of his pit at the Coronado Speed fest a with a big 'JBA' sticker on the windshield so I know he's at least doing some C3 parts.
Old 10-20-2008, 02:21 AM
merrell.a
merrell.a's Avatar
Is the heat riser off the headers reuired, is it part of the whole emmisions set up?
Old 10-20-2008, 03:57 AM
SanDiegoPaul
Support Corvetteforum!
SanDiegoPaul's Avatar
I use Hedman #68301. The Dyno shop will sell you a heat riser for the header collector.
Old 10-20-2008, 09:22 AM
fauxrs2
fauxrs2's Avatar
I use the same and the Dyno Shop sold me a heat riser for the header collector. No welding required tubes already mounted
Old 10-20-2008, 12:09 PM
jeffp1167
jeffp1167's Avatar
without a BAR label OE number attached to them you can be assured a smog technician will fail your car simple as that. Sorry to disappoint you.
Old 10-20-2008, 01:46 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
If you have headers with all the attachements best you can hope for if its failed is to take it to the state referee. I did that years ago with a set of Hedmans on a Blazer with a 350-454 swap and they passed it. Had the fittings, went to Pep boys and bought a universal air pipe kit, hooked everything up and got a sticker.
That was many years ago so who knows whats changed.
Old 10-20-2008, 04:10 PM
fauxrs2
fauxrs2's Avatar
10 years in CA 5 smogs at test only station (usually the strictest) not once has the LACK of an BAR label or OE number been an issue.
If everything is connected and working you have very little to worry about.
Old 10-20-2008, 04:11 PM
fauxrs2
fauxrs2's Avatar
If you have headers with all the attachements best you can hope for if its failed is to take it to the state referee. .
thats the worst you can expect...not the best....I moved into Ca with these headers, have smogged it 5 times with these headers...no problem yet
Old 10-21-2008, 12:22 PM
merrell.a
merrell.a's Avatar
what type of headers are you using?
Old 10-21-2008, 03:16 PM
fauxrs2
fauxrs2's Avatar
Hedman #68301
Old 10-22-2008, 02:48 AM
merrell.a
merrell.a's Avatar
Thanks for the info. Did the air injection ports come already installed or did you have to put those on yourself? Second question, did you have any problems with an exhaust shop to put those on. Did they connect the remainder of the exhaust with out any grief? If so any recommendations on shops that could.
Here is what Iam running into, they make headers to fit the 81 with air injection ports. But they tell me they are not CARB approved. The CARB approved only go up to 80. I would hate to spend all that money, have to adjust the rest of the exhaust pipes to fit the new headers and it not pass smog.
Old 10-22-2008, 03:16 AM
RC81
RC81's Avatar
Merrell
I agree with you. Would like to put some on my 81 but dont want problems at the smog shop. Since the 81 has manifolds that look a bit like headers they may not notice though, thinking they are stock.
Old 10-22-2008, 05:35 PM
fauxrs2
fauxrs2's Avatar
these headers form Hedman have the AIR tubes already installed. The shop that did my exhaust had no issues connecting up a custom exhaust system to these headers.. the system consists of a custom front y-pipe with smooth merges from the 2 1/2" head pipes to a 3" single pipe, through a hi-flow 3" cat and then back out through another smooth y to 2 1/2s and mufflers.
This system has been smogged once since installed - no issues.
Old 10-23-2008, 02:22 AM
merrell.a
merrell.a's Avatar
Thanks appreciate your time in the response.
Old 10-24-2008, 09:02 AM
FB007
FB007's Avatar
Originally Posted by fauxrs2
Hedman #68301
Since you A.I.R. pipes are capped off, your smog tech is merely ignorant.
To CA legal headers w/air injection emission ports
Old 10-24-2008, 09:07 AM
fauxrs2
fauxrs2's Avatar
You presume then, that is the condition that the smog tech sees it in...
Happy now?
Old 10-24-2008, 10:53 AM
FB007
FB007's Avatar
Forgive me. Your legal one day a year. How special is that?
Old 10-24-2016, 01:04 PM
Snoopysvet
Snoopysvet's Avatar
In California I would call that a win.
However I would get a Emissions sticker from Ecklers. Get the Federal emissions sticker that does not require AIR injection.
https://www.ecklerscorvette.com/inde.../9055/image/0/
Quick Reply: CA legal headers w/air injection emission ports
