Can anyone explain this ground wire from intake manifold to rear frame? (see picture)
As I am working through the electrical system on my '81, I am running into mysteries here and there.
The latest is a heavy gage ground wire bolted to my manifold that runs back and under all the way to the rear chassis where the battery ground is bolted. Since this is a non-stock engine setup (350 w/Canfield heads, Edelbrock aluminum intake, etc) is there some logic to having this ground wire attached? It has some real issues with bubba splices, etc but seems to just be a straight run for ground. If its not needed I'd like to remove it. Otherwise, I'll need to run a new one because of the crappy splice/repair attempts. (The red part is an 8" piece of wire spliced in to 'repair' the ground wire.)
I have the AIM, but am not sure how to adapt the diagrams to my particular situation.
I was describing how you could do it without changing the end under the car. Mainly to get the end pictured off the upper side of the engine. Here is the stock set up on my '77. Pass. side pictured. mike...
Remember that the ground has to carry essentially the same current to the starter as the power wire from the battery, though not as far so doesn't have to be quite the same diameter. If the ground that you showed was the only one then it would have fried every time you start the car. You may have a larger ground at the front of the engine (where mine is). There are also a number of possible paths to the frame including the coolant through the rad, exhaust through the crossmember, solid engine mounts....
I think on some years, the engine ground strap when to a nearby point on the frame. You should use a big cable for ground. I could imagine some of the auto store generic ground straps could be a little thin. Also, try to get pure copper. I think some of them have multi-strand aluminum wires. I'd check to see if Lectric Limited sells pure copper cables.
On 80-82 cars there should be 2 wires that go directly from the alternator to the battery area. It is odd that your ground wire is the red though. Originally a red one ran from the power terminal on the back of the alternator to a junction block in the battery box. A black wire ran from the back of the alternator to the frame crossmember directly below the battery box. It looks like your car is using the red wire for a ground. Can you tell where the wire that attaches to the power terminal on the back of the alternator goes?
I removed it completely. Checked and found the stock grounds in place. Everything seems to be ok after a month of occasional driving. I'm sure the PO had a good reason for it, but heck if I can figure out what that was.
Thanks for the advice folks. Love this forum.
