Old 03-25-2015, 06:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Power Window Initialize (Resetting the Window Indexing)
Old 10-16-2010, 05:58 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Default Power Window Initialize (Resetting the Window Indexing)
After a power reconnect such as battery replacement, the
window index-up feature will not function until the system
is initialized. Once power is restored, do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds and
release.
Remember to do both windows.
This is called resetting of the window indexing or power window initialize and is in the owner's manual. See page 2-17 of the 2005 owner’s manual, page 2-18 of the 2006 owner’s manual, page 87 of the 2007 owner’s manual, page 2-18 of the 2008 owner’s manual, page 2-18 of the 2009 owner's manual, page 3-18 of the 2010 owner's manual, page 2-18 of the 2011 owner's manual, or page 2-19 of the 2012 owner's manual.
The following 16 users liked this post by Vette_DD:
anchito27 (08-08-2021), bgspot (07-24-2017), FlyinZX11 (11-13-2017), foundvettelifeisgood (08-06-2016), jdvann (01-16-2018), jeffs64 (02-18-2018), MickVette (10-08-2016), RichKiss (09-23-2015), salt6 (11-19-2017), Scout05 (11-04-2019), speck (11-28-2017), stavanger (06-09-2017), toddbd01 (07-03-2019), vertigogo (10-15-2015), VroomForTwo (09-21-2016), Z2Z (04-02-2016) and 11 others liked this post. (Show less...)
Old 10-16-2010, 09:20 PM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Thanks Jim. Asked a fair amount of times and pretty sure that most would look here before the manual.
Old 10-16-2010, 10:02 PM
RRVettes
RRVettes's Avatar
Good info Jim...a topic that comes up often. I added your thread to the C6 FAQ.
Old 10-16-2010, 10:25 PM
Vette_DD
Vette_DD's Avatar
Old 10-23-2010, 04:15 AM
60av8tor
60av8tor's Avatar
Thanks much !
Old 10-23-2010, 06:40 AM
Full Metal Jacket
Full Metal Jacket's Avatar
AWESOME!!!! I disconnected the battery and immediately noticed that the window did not 'index" when i shut the door..
thanks... Also would this cause the alarm not to sound when i open the door..
After reconnecting the battery, I arm the alarm/lock the car yet i am still able to open the door from the outside and the alarm doesnt go off?? Never did that before..
Old 10-23-2010, 07:19 AM
talon90
talon90's Avatar
NCM Ambassador
If you have the fob with you that's why. You can lock the door but if you have the fob on your person when you try to open it, the car will unlock. That's part of the purpose behind the fob system. When you press the pad on the door switch, the car looks for the fob. If it sees a valid fob it will unlock the door (locked, alarmed or otherwise). Try locking the door with the button on the fob then place the fob on the ground 50 feet away and then try to go back and open the door and you will find that won't open. Go back with the fob in your pocket and it will.
Old 11-05-2010, 06:36 PM
subseawellhead
subseawellhead's Avatar
I just had to IM this to the wifey as she changed her second battery today
And again, I am not even in the country
Old 12-04-2010, 10:36 PM
purple heart
purple heart's Avatar
Another proven method that works (at least for my 2008 and may work for all years???) is to:
1. start the car-with both doors closed...
2. raise and lower both windows 3X together
3. on the 3rd time on the up movement ( you start with them up, go down and back up = one time!), SHUT OFF THE CAR, EXIT AND CLOSE THE DOOR. THE WINDOW SHOULD INDEX ITSELF. AND ALL IS WELL! IF NOT, JUST REDO THE ABOVE PROCEDURE; SOMETIMES IT MAY TAKE 2 OR 3 TIMES. Most of the time, it takes once; one time it took me twice!
But it does work!
Voilla! Success!
Old 12-04-2010, 11:03 PM
Vette_DD
Vette_DD's Avatar
But it does work!
Voilla! Success!
Sure seems like a lot of extra work, THAT MAY OR MAY NOT WORK.
The one in the manual works every time. I guess that's why it's the one in the manual.
Old 12-08-2010, 04:43 PM
garyhunts
garyhunts's Avatar
Thanks so much Jim and to all that lent their expertise...The Forum is an invaluable tool to say the very least.....Happy Holidays !!!..............Gary
Old 12-08-2010, 06:08 PM
phileaglesfan
phileaglesfan's Avatar
Great sticky! I found out this procedure when I hooked up the battery after installing an insulation kit. I thought I broke the car since the windows would not go up. I did find it in the Owner's Manual though.
Old 12-30-2010, 09:15 PM
Mainvillain
Mainvillain's Avatar
Thanks a bunch, today I noticed that my driver's side window wasn't going up when I closed it.. came "here" before starting to panic that the door was broken.
This forum is so helpful!
Old 12-30-2010, 11:47 PM
SpryGeezer
SpryGeezer's Avatar
Me too. My driver-side window index-up feature stopped functioning yesterday for no apparent reason. Haven't had any electrical anomalies or service, battery OK, never had DBS, everything else has always worked. Did the UP/HOLD/UP AGAIN/HOLD drill and it worked, thank you.
Old 01-05-2011, 08:00 AM
cincykid
cincykid's Avatar
This happened when I got my windows tinted. They hit the door switch so the window would stay up when the door was opened. The way I did it was get in the car, put the window all the way up holding the switch for xtra 3 seconds, all the way down, hold for another xtra 3 seconds, and then all the way back up, holding for xtra 3 seconds and that was it. I love my vette!!
Old 01-05-2011, 09:33 AM
fyreline
fyreline's Avatar
Received 1,267 Likes on 508 Posts
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
I finally had to do this for the first time yesterday, and I actually remembered the correct procedure from reading this sticky.
A little knowledge is a dangerous thing, and I have as little as anyone.
Old 01-05-2011, 09:00 PM
Ron R
Ron R's Avatar
Thanks for posting, had to do this today. Hadn't driven the vette for over a month and the radar detector drained the battery.
To Power Window Initialize (Resetting the Window Indexing)
Old 01-07-2011, 11:36 PM
Its Hers
Its Hers's Avatar
I learned about the window indexing the hard way.....took a few days to get the car dried out after I noticed that the windows were not closing all the way.
Old 01-15-2011, 08:10 PM
thomaskh
thomaskh's Avatar
Drivers window has stopped about three inches from top.
It will go down all the way but stops when trying to close.
Motor slows to stop position.
How do you remove door panel?
Anyone experienced this situation, suggestions?
I did replace battery months back, no window indexing problem experienced till present.
Old 01-16-2011, 12:00 AM
Vette_DD
Vette_DD's Avatar
Since this is not a problem with window indexing, it's possible that no one here would see your post. Several have posted in the forum in the past about removing the door panel, but I do not have a link to those threads.
You may want to post a new thread in C6 General asking for help with this. However, I'd look first in the C6 FAQ sticky.
Quick Reply: Power Window Initialize (Resetting the Window Indexing)
