Vortex Lip Install (Pics)
Old 02-01-2011, 12:31 AM
Gr8Wht
CF Veteran
Support Corvetteforum!
Gr8Wht's Avatar
St. Jude Donor '10-'12
Default Vortex Lip Install (Pics)
I purchased a carbon fiber Vortex Lip from Quik Z06 (Corvette Creationz) group buy. At first I had second thoughts about adding carbon fiber to a C5, but after seeing a couple of pictures I thought a hint of carbon fiber all around would be just enough and look awesome. I'm still waiting for my side skirts and I'm not sure what to do about the rear-end yet. I've seen a couple of threads regarding a carbon fiber diffuser (Corvette Creationz Z06 group buy) and have even thought of carbon fiber vinyl, but I'm still undecided.
Ok, so back to the Vortex Lip install....
1. Jack up the front-end to gain access under the front bumper.
2. Remove the air deflector, left and right outer valances, and fascia close out panels.
3. The Vortex Lip has to be drilled for mounting. This could be a little scary (drilling something you just spend $$), but it's not all that bad. Kind of like drilling through plastic. My lovely assistant (wife) helped me align the lip so that I could mark the center two (one on each side) holes.
Center hole location...
Center hole mounted...
4. Once you have the center mounted drill two holes (each side) and use original screws hole that mount the outer valances and close out panels.
Outside mounted...
5. Once you have the center and outsides mounted checked the fit before proceeding...
6. You need to drill through your front bumper, so hold the vortex lip to check the best location. I drilled through the vortex lip and bumper at the same time. Installed the lip with stainless steel hardware from Home Depot..
Hole location...
Mounted...
7. Next, you will need to cut the nice carbon fiber lip....Yes cut! For the center mounting locations, the manufacture built up the sides which conflicts with the center air deflector being installed.
8. I used a Dremel to cut and form the vortex lip (it was like butter).
Air Deflector Installed...
Finally, Vortex Lip installed!
Thanks Pete Quik Z06 (Corvette Creationz)....I love it!
Old 02-01-2011, 12:32 AM
02*C5
02*C5's Avatar
looking good
Old 02-01-2011, 12:34 AM
Qwik01
Qwik01's Avatar
Nice write-up! Looks good!
Old 02-01-2011, 05:38 AM
0Quik Z06
Former Vendor
Quik Z06's Avatar
Scott, looks sweet.....but we meed more pix Thanks for posting the write up, I know your a busy individual so it's appreciated
Old 02-01-2011, 06:48 AM
Grim Reaper
Grim Reaper's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
looks great
Old 02-01-2011, 06:55 AM
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Looks nice
Old 02-01-2011, 07:28 AM
Johnson 92
Johnson 92's Avatar
C5 of the Month 6/13
Lookin' good!!
Old 02-01-2011, 07:35 AM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,096 Likes on 808 Posts
Originally Posted by Grim Reaper
looks great
Size:  18.3 KBName:  Grim_Reaper.jpg
Old 02-01-2011, 07:47 AM
Robert 2000
Robert 2000's Avatar
Looks good... Now I want one
Rob
Old 02-01-2011, 07:49 AM
4SFED Z
4SFED Z's Avatar
Looks good, but I think that the holes should be tapped in already,should have came with the mounting hardware, and no cutting.....
Just seems mike a lot of work to get this to mount right. Wonder if there is a reason for holes not being there and the spoiler fitting correctly?
Old 02-01-2011, 08:17 AM
MSG C5
MSG C5's Avatar
Received 2,673 Likes on 1,479 Posts
2018 C5 of Year Finalist
The manufacturer needs to fix this and perhaps add the pre-drilled holes/hardware. Even if they have to increase the production cost to do so and raise the retail cost $50 to cover the expense. This should be bolt on/plug & play.
Very nice write up and pics. Thanks!
I'm a little concerned with how far back the spoiler goes back as it seems to cover a lot of the original open air flow box. It seems as though by looking at the pictures, there is only about 1" between the back lip of the splitter and the OEM flex spoiler which is designed to push air up into the intake. Or does the front opening in the splitter supposed to direct the air up instead?
In the end, it looks great!
BTW - you might want to get a set of Fangs.
Old 02-01-2011, 08:59 AM
corvettedaddy11
corvettedaddy11's Avatar
Yea, that's cool as sh@t......!
Old 02-01-2011, 09:37 AM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
Very nice Bro... Now we need pictures of "said" lovely assistant...
Old 02-01-2011, 10:20 AM
rudolph schenker
rudolph schenker's Avatar
Old 02-01-2011, 10:21 AM
jrose7004
jrose7004's Avatar
Received 1,673 Likes on 1,296 Posts
I think it looks great! And you did a great how to write up, BUT> I'd knock that thing off my car the very first time I back out of my driveway,
Old 02-01-2011, 10:28 AM
rdline
rdline's Avatar
Great job, looks goods and thanks for all the detail for your install.
Old 02-01-2011, 10:31 AM
HiVoltge
HiVoltge's Avatar
St. Jude Donor '08
Now I want one as well!! Looks great, although I agree in that it should be prepped to fit without any modifications needing to be made..
To Vortex Lip Install (Pics)
Old 02-01-2011, 11:39 AM
Mark Maple
Mark Maple's Avatar
Looks great. Can you post some pictures from some different angles. I also have a QS vette and want to see how the CF lips looks.
Thanks,
Mark
Old 02-01-2011, 12:16 PM
doublec4
doublec4's Avatar
Thanks! Please more pictures from farther away and different angles!
Old 02-01-2011, 12:31 PM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
+1
Looks like a straight forward easy install.
Trying to decide if I like the vortex or if i want to see how the new C5R splitter looks before i make the call.
Quick Reply: Vortex Lip Install (Pics)
