Hood Vents
Old 06-30-2011, 01:54 PM
Deceptikon
Deceptikon's Avatar
Default Hood Vents
Im looking to add vents to my stock C6 hood. Does anyone have pictures of vents they have added to their C6
Old 06-30-2011, 05:56 PM
wolfdogs
wolfdogs's Avatar
Location: Stafford VA, home of our wolf den. No house break ins to date.
I think most folks just buy an aftermarket hood to the design of their choice. Are you talking about cutting and pasting?
Old 06-30-2011, 06:07 PM
theofel
theofel's Avatar
St. Jude Donor '10-'13
Contact Breatless Performance. Iv'e seen a few cars with vents in hoods that were installed by them. And they look great.
Old 06-30-2011, 10:52 PM
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Support Corvetteforum!
Steve Snake Driver's Avatar
User CPT Z or something similar had a hood with vents installed (two narrow lateral vents - one each side of the center bulge). It looked good.
Old 06-30-2011, 11:11 PM
dovervold
dovervold's Avatar
Well, here is what I did on my last car: 07' with A & A S/C, cam, headers... was looking to extract heat and cool under hood temps. Worked extremely well, I had a lot of compliments, took some guts to cut a hole in the stock hood. PM if you want details on how I did it with basic hand tools in my garage:
Good luck, lots of great after market hoods if you want to spend the coin:
Old 07-01-2011, 02:58 AM
jpuli28
jpuli28's Avatar
I believe LG makes a single louvered center insert similar to their LG Challenge Hood.
Old 07-01-2011, 03:00 AM
jpuli28
jpuli28's Avatar
Originally Posted by dovervold
Always wondered what that would look like w/o a SC under the window. Needs a little more bling but kinda nice.
Old 07-03-2011, 06:27 PM
TLTONEY
TLTONEY's Avatar
Old 07-03-2011, 07:02 PM
Stan0324
Stan0324's Avatar
Problem with hood vents is that you need to have a finished trim around the edges. Normally, this edge will be higher than the vent. I think it looks terrible. Replace the hood with one that has what you are looking for built in. Looks much nicer.
paulrichy (02-21-2017)
Old 07-05-2011, 03:19 PM
Deceptikon
Deceptikon's Avatar
Thanks for the input. I am looking to cut the stock hood and add some vents. Will look into Breathless performance too.
Old 02-13-2014, 02:07 PM
Corinthian
7th Gear
Corinthian's Avatar
APR might have what you are looking for..
CF-100002 Hood Vents Narrow
CF-100004 Hood Vents Wide
http://aprperformance.com/popup_image.php?imageurl=http://aprperformance.com/images/zoom/OJSSMJ/Narrow_hoodvents.jpg
http://aprperformance.com/popup_image.php?imageurl=http://aprperformance.com/images/zoom/OJSSMJ/Wide_hoodvents.jpg
Old 02-20-2017, 11:48 PM
GNasty1560
Navigator
GNasty1560's Avatar
Default C7 vent on C6
I like the C7 vent...cheap as it is- and bought a stock hood.
I would have liked to place it near front of car BUT because of clearance issues (unless I mod the intake) I had to place it closer to windshield. Need to figure out how the edges will need to be done. It will take time to finish this sucker
Old 02-21-2017, 04:48 AM
Corinthian
7th Gear
Corinthian's Avatar
Default Hood Vents
I mounted APR Universal Vents
http://www.garaget.org/?car=162626&image=3678011
http://www.garaget.org/?car=162626&image=3711088
Old 02-21-2017, 07:41 AM
veloz
veloz's Avatar
Default my vent
my design
Old 02-21-2017, 09:45 AM
C U IN REARVEIW
C U IN REARVEIW's Avatar
Old 02-21-2017, 09:48 AM
C U IN REARVEIW
Old 11-12-2017, 11:28 AM
GNasty1560
Navigator
GNasty1560's Avatar
Painted victory red w cyber grey vent to match my headlights. Still needs to be clearcoated maybe in a week or two. Thanks to members asking me about it. Its a functional heat release hood
To Hood Vents
Old 11-12-2017, 02:10 PM
BWF07
BWF07's Avatar
St. Jude Donor '11
Oldtimer
Unless your engine is built and produces a lot of heat, the only thing I can see these for is for looks. Now if they are for looks think about the amount of water that can now get it when you wash the car or drive it in the rain, YES I said rain.
Old 11-12-2017, 05:29 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Engines and all electrical fittings are sealed. Water is not an issue at all. You can hose off your motor all day. In fact it is a great way to detail and clean the motor.
The biggest advantage to hood vents is aero. It reduces front end lift at high speed.
Had a vented hood for 6+ years now. Zero issues. Driven in rain, through car washes. Does little to nothing for cooling, does great for aero.
Old 11-13-2017, 10:49 AM
EVILFACE
EVILFACE's Avatar
Attachment 48151870
Attachment 48151871
Attachment 48151872
I can understand cutting a hole for a polished 6-71 blower or high rise with velocity stacks. But a hole to see yellow plastic coil covers?
TNRC (03-14-2018)
Quick Reply: Hood Vents
