Every Tech should have this LS Timing cover Alignment Tool!
Old 05-30-2013, 02:38 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Every Tech should have this LS Timing cover Alignment Tool!
AlignIt Tools are used to align the Rear Main and Timing Covers and install the seals!
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 and all GM v8's from 1997-2013 Timing and Rear Main cover and seals. Works with all LS based engines!
Here is a couple simple but very effective tools to help you make easy work of aligning your Timing and Rear Main Covers. CNC Machined to exact tolerances, the AlignIt tools
get the covers centered perfectly with the crank. The O-ring design makes for a perfect snug fit no matter the temperature that can cause expansion/contraction of engine covers, crank & tools
that will hinder a perfect fit. The O ring design eliminates this problem. After the covers are centered and torqued down, use the AlignIt Tools to install the seals in seconds!
Available in the Pro Series 6061 Aluminum Anodized and the standard PVC Plastic. Both are CNC Machined to exact specs
from Billet materials.
www.saccitycorvette.com/AlignItTools.html
If you're doing a Rear Main Seal or Engine Build, its a good time to start keeping unfiltered oil out of your bearings and lifters! Check these Billet Oil System Improvement parts out!
https://www.saccitycorvette.com/OilS...provement.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 08-20-2013, 12:04 PM
thumpinc5
thumpinc5's Avatar
I bought one of your front cover alignment tools for my LS1 build. I have to say that it's a great product and it worked perfectly. Definitely worth the investment.
Frank
Old 08-21-2013, 01:19 PM
SacCityCorvette
Supporting Vendor
Thank you Frank for your business and the good word!
Old 10-18-2013, 12:21 PM
SaberD
SaberD's Avatar
just ordered my timing cover and oil pump tools the other day. replacing the timing set and oil pump since I have to do the harmonic balancer.
Old 10-21-2013, 07:20 PM
SacCityCorvette
Supporting Vendor
Thank you for your business SaberD!
Christian
Old 10-23-2013, 08:52 PM
Z06ufgrad2002
Z06ufgrad2002's Avatar
How well do the Front cover and oil pump tools work with the block still in the car and the oil pan still mounted?
Old 10-24-2013, 06:07 PM
SacCityCorvette
Supporting Vendor
Hi Z06ufgrad2002,
Should make it easier to get the covers lined up and the seals installed.
Thanks,
Christian
Old 11-12-2013, 12:21 AM
The Highlander
The Highlander's Avatar
We need some plates that bolt to the front cover lower bolts and bottom of block to get PERFECT alignment.
Old 11-13-2013, 05:21 PM
SacCityCorvette
Supporting Vendor
Hi Highlander,
What if you set the oil pan on there as a guide?
Old 06-05-2014, 07:53 PM
Z06ufgrad2002
Originally Posted by SacCityCorvette
Hi Z06ufgrad2002,
Thanks,
Christian
Used the tools and they worked flawlessly. Thanks
Old 06-13-2014, 06:29 PM
SacCityCorvette
Supporting Vendor
Thank you Z06ufgrad2002!
Old 09-09-2014, 12:05 AM
SacCityCorvette
Supporting Vendor
The Hub Simulator Tool is for those that do not want to remove the seal.
It simulates using your hub to align the timing cover with the seal in place.
Old 12-29-2014, 06:53 AM
ArtGle
Support Corvetteforum!
ArtGle's Avatar
Somewhere, (now I have to look for it) I believe I have a digital copy of a photo of the very first Corvette at the end of the assembly line, surrounded by bigwhig executives and others, all scratching their heads because the car failed to start due to having used the fiberglass body as ground.... LOL
Old 12-29-2014, 03:55 PM
REDZED2
REDZED2's Avatar
Hmmmm.. Guess you don't have to lubricate the crank nose or seal before hammering it on with your tool?
Old 12-29-2014, 07:50 PM
SacCityCorvette
Supporting Vendor
Hi wantbluC6,
The seal lips should have lube before you slide the harmonic balancer hub on. You don't have to put anything on the out side of the seal before tapping it in. Some do like to put a little sealant for insurance against leak though.
Thanks
Christian
Old 12-30-2014, 01:55 AM
REDZED2
REDZED2's Avatar
Hi wantbluC6,
Thanks
Christian
Oh crap.. my bad.. It's been a while, I flipped things around in my head. I know now the proper procedure for install.
Old 08-03-2015, 11:06 AM
timewstr
timewstr's Avatar
Default oil pump
Did you discontinue the oil pump tool? I'm going to get the front cover tool. Great idea.
To Every Tech should have this LS Timing cover Alignment Tool!
Old 08-03-2015, 05:17 PM
SacCityCorvette
Supporting Vendor
Hi Timewstr,
Yes we discontinued the OP tool.
Thanks in advance for your business!
Christian
Old 09-02-2015, 11:34 AM
tommypenguin
tommypenguin's Avatar
Just received my alignit tools, thanks.
Old 09-02-2015, 02:17 PM
SacCityCorvette
Supporting Vendor
Thank you for your business tommypenguin, we appreciate it!
Christian
Quick Reply: Every Tech should have this LS Timing cover Alignment Tool!
