Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Old 09-07-2013, 03:03 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Default Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
2013 C6 Z51 Sway Bars!
Greetings Friends,
We have the Z51 sway bars kit with the Genuine GM bushings for $257.95
The reason people use these bars most on the C5’s and the C6’s is because unless you’re running 325 width tires in the rear, these are the way to go. These bars don’t cause the vehicle to ride “stiffer” per se. They are mostly for the cornering ability.
You know that feeling when you’re going into the turn and the car leans pretty heavily? These bars are meant to make the vehicle feel flatter in the turns and corner much better in the turns. Another advantage is the handling when you’re coming out of the turn. When you come out of the turns you will not be fighting the wheel as much as you would with the stock bars. These bars, since they’re thicker, make it easier all the way through the turns.
Below are the specifications and comparisons of the C6 Z51 sway bars compared to other Corvette suspension packages.
Corvette Sway Bar Specifications
Suspension Front (mm) Rear(mm)
C5 base 23.0 19.1
C5Z51 (97-99) 25.4 21.7
C5Z51 (00-04) 28.6 23.6
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
We offer these sway bars with the 2013 C6 Z06 shocks. Also, whether it is a C5 or C6, coupled with the 2013 C6 Z06 shocks it makes a total different handling package. This package speaks for itself as we have many testimonials from many customers from whom we sold these to here on the forum!
To order, please call 484-334-8833 or go to the link below to order!
http://www.cultragfactoryparts.com/c...kit/c6z51bars/
||--Genuine GM C6Z51 Sway Bar Kit--||
25919502 – Front stabilizer bar
10339124 – Rear stabilizer bar
10387838 – Front stabilizer bar bushings (2)
15241135 – Rear stabilizer bar bushings (2)
Complete kit front and rear is $257.95
Use part number c6z51bars on our website.
2013 C6 Z06 Shocks!
We sell the 2013 C6 Z06 shocks for $309.95. Many C5 customers ask us why we don’t recommend the 2004 shocks over the 2013. Many people also say that the C6 shocks are only developed for the C6. If you look at all of the basic suspension components between the C5 and C6, they are very much the same. The reason we don’t recommend the 2004 Z06 shocks over the 2013 C6 Z06 shocks is simply because of the price and customer feedback. We have many customers who have tried both sets of shocks and cannot tell the difference between the two, so why not purchase the lesser expensive set!
For the C5, not C5 Z06, we also recommend the C6 Z51 sway bar kit. The C6 Z51 sway bar kit coupled with the 2013 C6 Z06 shocks is our most popular suspension and handling upgrade for the C5.
http://www.cultragfactoryparts.com/c...t/c6z06shocks/
||--Genuine GM 2013 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) $309.95 total.
For the shocks on our website, use part number c6z06shocks.
The C6 Z06 shocks will work on stock C5’s and C6’s without modification.
Thank you,
Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 09-25-2013, 10:35 PM
209TIME!!!
209TIME!!!'s Avatar
what do i need if i have f45 or f55 suspension?
Old 09-27-2013, 08:04 PM
Gene Culley
For the replacement of electronic shocks you'll need to order the shock simulators from aftermarket online vendors. The simulator will make the computer think the electronic shock is still attached. That is all.
Old 10-01-2013, 02:51 AM
209TIME!!!
209TIME!!!'s Avatar
so i can get the shock simulators and run the C6 Z06 shocks without any problems?
Old 10-06-2013, 09:52 PM
Gene Culley
Yes, that was my advice.
Old 11-07-2013, 09:40 AM
ArtGle
Support Corvetteforum!
ArtGle's Avatar
O.K., so I'm putting my C-5 Base Coupe up for the winter.
Just bought it a month ago.
Active Suspension is fully functional, and I'd rather not remove it.
When I PUNCH it, display states "Active Suspension On" and changes back to odometer.
Are these C6 Z06 shocks going to work with this?
Newbie here, so stop laughing.
109K miles, and shocks are kinda "Skooshy", (mild up and down on highway, makes me nervous with that 'Floating' feeling).
So I know the shocks need replacing.
Old 11-08-2013, 11:00 PM
Gene Culley
If you have the electronic suspension all you need are shock simulators. The shock simulators plug into the connector where the shocks used to be plugged in and this tricks the system into thinking the electronic shocks are there. We don't sell them but many other forum vendors do.
Old 11-08-2013, 11:31 PM
Pintoblades
Pintoblades's Avatar
Great info! So if you use shock simulators...then your car will be in competition mode 100% of the time? Mine has Active handling system also.
Old 11-10-2013, 08:50 PM
Gene Culley
You'll have to check with the others here who have done this on the board. I'm not sure what mode it is in permanently.
Old 11-23-2013, 12:16 AM
ArtGle
ArtGle's Avatar
I think I've read that you can have the "Active Suspension" removed (software) from the computer using the GM TECH II Diagnostic Scanner.
Old 11-27-2013, 09:50 PM
Gene Culley
I hope you guys are busy working on your Black Friday lists!
Old 11-27-2013, 10:07 PM
Pintoblades
Just ordered some Z06 shocks from you guys last Monday, can't wait to get them on!
Old 11-28-2013, 09:46 AM
98gorby
98gorby's Avatar
Took 2 days for me to recieve mine, plus im in canada. Great service Gene and company!
Old 11-28-2013, 10:17 PM
Gene Culley
Thank you for your business. Let us know how you like the mod!
Gene Culley
Thank you for your business as well and the positive feedback. That is an awesome time frame especially to Canada!
Old 11-30-2013, 08:20 AM
4XLR8N
Pro Mechanic
4XLR8N's Avatar
Received 1,652 Likes on 1,209 Posts
Hi Gene
Looking to upgrade my '97 Corvette (base suspension) with your sway bars and shocks...wondering about the end links.
Do you sell the metal sway bar end links? If so, what are the correct p/n's for front and rear?
Thanks!
Old 11-30-2013, 12:01 PM
Gene Culley
Originally Posted by 4XLR8N
Hi Gene
Thanks!
We do sell the end links. I'll paste the link to order below. They are $26.75 each.
http://store.gmpartshouse.com/parts/...&siteid=214638
To Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Old 11-30-2013, 12:29 PM
mrm13
mrm13's Avatar
I just placed my morder yesterday. Thank you very much. Great service.
Old 11-30-2013, 06:39 PM
SONIC99
SONIC99's Avatar
I ordered and installed mine last month (with metal end links) to upgrade the suspension on my 99 FRC with Z51. I was very happy with the service and results.
Old 11-30-2013, 07:24 PM
Gene Culley
Thank you guys for your business. I certainly appreciate it!
Quick Reply: Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
