C5 Smoked Turn Signal/Corner Lamps W/ LED Packages
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Only 1 left in stock
Starting at $90
Order here <----
LED OPTIONS
Amber LED Package. This includes an amber day time running light led and an amber side marker led for your corners (4 leds total) + $40
White LED Package. This includes white day time running light leds and white side marker leds for your corners (4 leds total) + $40
Amber DRL/White Side marker package- This includes amber day time running light leds and white side marker leds for your corners
+ $40
White DRL/Amber Side marker package- This includes white day time running light leds and amber side marker leds for your corners + $40
Switchback 60 LED DRL/Amber Side marker package- This includes our 60 LED Switchback LEDS and amber side marker leds for your corners. The switchback LEDS are amber in the day and at night when your lights are on they turn white. When the turn signal is applied they switch back and forth from amber to white. + $55
Switchback 60 LED DRL/White Side marker package- This includes our 60 LED Switchback LEDS and white side marker leds for your corners. The switchback LEDS are amber in the day and at night when your lights are on they turn white. When the turn signal is applied they switch back and forth from amber to white. + $55
Be advised adding LEDS in the turn signal housings will cause your lights to hyperflash (flash really fast). A product called a Hyperflash Harness is available to fix this.
**NEW** Amber or white LED Strip- This strip is placed inside the DRL housing and properly sealed from water. Comes wired with plug n play harness that plugs into side marker lights so the led strip will come on with parking lights and normal lights. +$89.99 (please include color choice in "special instructions" when checking out).
Starting at $90
Order here <----
Starting at $90
Order here <----
LED OPTIONS
+ $40
Starting at $90
Order here <----
Banned Scam/Spammer
No, this is as close as we have to those. Not sure if/when those all clear units will be back. They've been out for a while.
Zo&Shel (10-15-2016)
Received 3,866 Likes
2015 C5 of the Year Winner
JW hasn't been on here for quite some time. I would look elsewhere. Not sure what happened to him. He was a great vender.
St. Jude Donor '13, '15
Glad I got my tinted corners from him before he went under. Never seen them on any other C5 around here. Works good with my gunmetal wheels and lower wrapped rear fascia.
The following 3 users liked this post by terrywerst:
Good to know. Thanks. Glad he's still doing well.
Received 3,042 Likes
Ok, but where did you go?
