** New C7 Front License Plate Brackets Available from Top Flight Reproductions **
C7 Corvette Front License Plate Brackets
If you live in a state that requires a front license plate, we have two great solutions for your C7 Corvette. Both of the Top Flight Reproductions front license plate brackets allow more air flow than the standard GM grill mount and attach with just two fasteners. There is no drilling or modifications required to your corvette.
** Features of the "Low Profile Mount" include less blockage of air flow, a sturdy aluminum construction with a black powder coat finish that attaches using existing screws. **
** Features of the "Grill Mount" include a Slim-Line look, an increase in air flow through the grill compared to the GM mount as well as ease of installation. **
NOTE: The GM C7 and C6 Body Colored License Plate Frames (sold separately) can be used with all of the Top Flight Front License Plate Brackets to enhance the look of the front plate.
ORDER HERE: http://www.topflightrepro.com/corvet...brackets.shtml
C7 Front License Plate Bracket "Low Profile Mount"
Shown with optional GM colored frame
Mounts to the bottom of the lower front bumper using two existing screws
C7 Front license plate bracket "Grill Mount"
Return the GM Front License plate bracket P/N 22830069
back to us and we will issue you core refund
(the P/N is located on the back side of the part).
Mounts using the Fastener Kit shown below
Grill Mount Fasteners qty of 2 per kit
** Please note that these are not supplied with the above
"Grill Mount" Front license Plate Bracket. If you have the GM
Grill mount you can use the same two fasteners. If you do not
have the GM Grill mount you will need to order this fastener kit. **
We got the low profile bracket and installed it. It looks good. A few things to note.
1. The product came without instructions
2. There are no instructions for the C7 on the website that we could find
3. Product requires you to bend the license plate to put it on the bracket
Suggestions:
Create a video on you tube that shows how to install
Provide a list of tools needed
Philips Head Screw driver
1/4 inch hex head wench needed to remove and install the bracket under the bumper
Flash light to see under the car to find the screws and unscrew them
Suggestions:
Suggestions:
Suggestions:
2022 C8 of the Year Finalist - Unmodified
2022 C2 of the Year Finalist -- Unmodified
Trying to decide how/what to order and still would like some info;
1) I like your low profile mount, but it looks like it will cover up my lower full body stripes. It appears to me there would be more air flow however, with the low profile mount over the grill mount? Do I need to be concerned with blocking airflow with the grill mount on my Z06 (pic attached for ref)
2) I can't see on your order site how the 50% off second license plate frame applies? Carbon flash for the rear and either torch red or regular black for the front, suggestions?
Thank you for your help!
-Garry
-Garry
1) I like your low profile mount, but it looks like it will cover up my lower full body stripes. It appears to me there would be more air flow however, with the low profile mount over the grill mount? Do I need to be concerned with blocking airflow with the grill mount on my Z06 (pic attached for ref) Our grill mount for the Z06 has 20% more airflow than the GM grill mount, you should not have any cooling issues.
2) I can't see on your order site how the 50% off second license plate frame applies? Carbon flash for the rear and either torch red or regular black for the front, suggestions? Carbon flash or Black for the front, if you're ordering two different colors it may not give you the discount, let us know after you order and we will issue you a refund
Best Regards
Peter C
Best Regards
Peter C
PS; thanks for the t-shirt offer it will have to be for the spousal unit, as I wear a 3XL, but it will work for her
Thanks,
-Garry
