What did you do to your C4 today?
The following 18 users liked this post by Dt86:
Antarctico (07-23-2019),
C4 1994 Dubai (04-09-2020),
cvsisinthehouse (03-20-2018),
DaleW (10-09-2023),
Garage Hermit (12-26-2022),
and 13 others liked this post.
The following 8 users liked this post by fl_799:
C4Spaceman (12-24-2020),
jbrianfoto (03-13-2024),
kdr3 (05-25-2020),
LTPower95 (05-03-2022),
and 3 others liked this post.
The following 4 users liked this post by Red89'-L98:
The following 3 users liked this post by don hall:
Well if you must know, I did a few things.
Took apart my dash and tested my MAF burn off module on my 1985 and it tested bad, so I ordered a new one for $109.
Repaired my passenger side floor light, I had to repin the connector.
Data logged today because my tuner accidentally screwed up the WOT AFR.
Checked my tire pressure.
And that's about it.
YellowEarl (04-19-2021)
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Went down and uncovered mine just to look at it
The following 6 users liked this post by FASTAZU:
attack_on_track (10-22-2020),
joendoodle (09-01-2019),
kdr3 (05-25-2020),
RedDevilRob (02-26-2020),
Ricks94vette (08-07-2023),
and 1 others liked this post.
Well if you must know, I did a few things. Took apart my dash and tested my MAF burn off module on my 1985 and it tested bad, so I ordered a new one for $109. Repaired my passenger side floor light, I had to repin the connector. Data logged today because my tuner accidentally screwed up the WOT AFR. Checked my tire pressure. And that's about it.
The following 8 users liked this post by MikeIz 82VETTE:
jay23ls (08-26-2022),
Rob790 (04-12-2021),
sb66 (08-14-2023),
The following 2 users liked this post by DanielRicany:
The following 2 users liked this post by gerardvg:
AussieTom (12-07-2019),
The following 19 users liked this post by randy ransome:
85C4OK (05-31-2020),
BubbaKahuna (04-23-2019),
Canadian94z07 (08-07-2022),
davethepolesitter (06-13-2022),
and 14 others liked this post.
Mvmiller28 (07-05-2018)
Cruise-In II Veteran
Soon as the rain stopped I just had to take the cleaner/wax to those white front wheels...
Then I determined that the RH headlight would not close, either electrically or by hand. Sooo, I just pulled on the headlights and pull the plugs to each motor...can't stand to see one light up...
Finally I pulled the front insert and installed my front tag, preparing to register in NYS...
Now this is a timely thread. I drove mine to the blacktop 2 1/4 miles away through the SLOP that our gravel roads have become due to the recent rains...took me 25 minutes. Then finally after shaking off the caked up mud and goo got it to town to have the "new" solid top's scratches repaired and painted along with getting the drivers door buffed out correctly because some jackwagon kid at a body shop had no clue what he was doing....heck it was so bad I couldn't have done worse Just hope the roads are fairly decent by the time it's done or I'll have to park it in my dad's garage in town and let his Buick sit out
astepup said that
astepup said that
The following 2 users liked this post by astepup:
Wine&Roses (10-27-2022),
The following 2 users liked this post by Scooter 94:
topgunvette (06-14-2019),
