2015-2017 C7 Corvette Z06 Clear Tail Lights In Stock @ CULTRAG Performance!
Old 12-06-2014, 11:42 AM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Default 2015-2017 C7 Corvette Z06 Clear Tail Lights In Stock @ CULTRAG Performance!
Greetings Customers & Friends,
The tail lights are $545.99 for the set. GM charges $50 per tail light as a core charge so the set is $689.99 to purchase. If you ship back to me your original tail lights in the boxes that the Z06 tail lights are shipped in we will give you the $100 back.
Click below to order on our website!
http://www.cultragfactoryparts.com/c...z06taillights/
Thank you!
Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 12-06-2014, 11:43 AM
Glen e
Glen e's Avatar
Pricey but nice if you like the look....
Old 12-06-2014, 12:17 PM
htownc7
Cruising
htownc7's Avatar
Could you post pictures?
Old 12-06-2014, 12:37 PM
Gene Culley
I have taken some but they need to be cleaned up and watermarked. I will have them soon, however, the are the same clear tail lights you would see on any C7 Z06.
Old 12-06-2014, 01:34 PM
abrimberry
abrimberry's Avatar
Cruise-In II Veteran
If ordered today, when will you ship them? Thanks.
Old 12-06-2014, 01:46 PM
Gene Culley
I will more than likely ship Monday. We purchased new boxes to ship both tail lights in their boxes for added protection so we are ready to rock.
Old 12-07-2014, 12:03 AM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
A question for you, Gene: Since the Z06's lenses are clear, I assume that the LEDs / bulbs that produce the lighting (for tail and brake lights) are red. Is the same true for the Stingray's bulbs / LEDs? I'd have thought that on the Stingray the LEDs / bulbs would be white; if that's the case, we'd have to switch to red ones if installing the clear Z06 lenses. Am I missing something here?
Old 12-07-2014, 12:24 AM
Mdm23
Mdm23's Avatar
LED bulbs don't have to be the color of the light that they produce.
For instance the bulb can be clear and still produce a red light. That is the case with these lights pretty much. I think they're lined with small led bulbs which are clear but when lit appear red. That's how they're able to pull off the design with no red reflector in the lamps.
Old 12-07-2014, 12:28 PM
mpuzach
mpuzach's Avatar
Yes, I understand that. What I meant was do the Stingray LEDs put out red light or white? I'm guessing white. If that's the case, those swapping for Z06 lenses will also need to swap out the LEDs. Or do the lenses that Gene is selling already include the LEDs?
Old 12-07-2014, 01:52 PM
Mdm23
Mdm23's Avatar
The Z06 lights will already have the proper led's inside. I'm pretty sure these lights are sealed assemblies, not meant to be opened. They're not simply different colored lenses. You would simply remove the stock Stingray tails, then install the Z06 tails.
Old 12-07-2014, 01:59 PM
MSG C5
Support Corvetteforum!
MSG C5's Avatar
Received 2,673 Likes on 1,479 Posts
2018 C5 of Year Finalist
Curious why GM would charge for cores? Do the recycle used Stingray tail lights and then resell them as new replacements?
Old 12-07-2014, 02:42 PM
motomanvette
motomanvette's Avatar
Too pricey for me.
Old 12-07-2014, 03:58 PM
Gene Culley
This post is correct. The tail lights are complete and ready to install. Unplug, plug in.
Old 12-07-2014, 03:59 PM
Gene Culley
I don't know the answer to this question. GM even has a core on the base Stingray tail lights. In the last 1-2 years GM has implemented a lot of core charges on a lot of different items.
Old 12-07-2014, 04:50 PM
mpuzach
mpuzach's Avatar
Great info. Thanks, guys.
Old 12-07-2014, 05:07 PM
mfear
mfear's Avatar
stock tail lights need to be water marked?
Old 12-07-2014, 07:00 PM
CSEVEN
Banned Scam/Spammer
CSEVEN's Avatar
The tail lights are easy swap, just need to loosen up the rear bumper.
To 2015-2017 C7 Corvette Z06 Clear Tail Lights In Stock @ CULTRAG Performance!
Old 12-07-2014, 07:01 PM
CSEVEN
Banned Scam/Spammer
CSEVEN's Avatar
I tinted mine as I installed the rear spoiler'
Old 12-07-2014, 09:34 PM
mdiiulio
mdiiulio's Avatar
He's taking pictures of the lights and those photos need to be watermarked for his business purposes.
Old 12-07-2014, 11:26 PM
MrBrightside
MrBrightside's Avatar
I just got mine all the way out here in Dubai; thanks Gene! I'll post pictures after I install them on my SGM
Quick Reply: 2015-2017 C7 Corvette Z06 Clear Tail Lights In Stock @ CULTRAG Performance!
