Base C6 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Premium Supporting Vendor
=&2013 C6 Z51 Sway Bars!
Greetings Friends,
We have the Z51 sway bars kit with the Genuine GM bushings for $257.95
The reason people use these bars most on the C5’s and the C6’s is because unless you’re running 325 width tires in the rear, these are the way to go. These bars don’t cause the vehicle to ride “stiffer” per se. They are mostly for the cornering ability.
You know that feeling when you’re going into the turn and the car leans pretty heavily? These bars are meant to make the vehicle feel flatter in the turns and corner much better in the turns. Another advantage is the handling when you’re coming out of the turn. When you come out of the turns you will not be fighting the wheel as much as you would with the stock bars. These bars, since they’re thicker, make it easier all the way through the turns.
Below are the specifications and comparisons of the C6 Z51 sway bars compared to other Corvette suspension packages.
Corvette Sway Bar Specifications
Suspension Front (mm) Rear(mm)
C5 base 23.0 19.1
C5Z51 (97-99) 25.4 21.7
C5Z51 (00-04) 28.6 23.6
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
We offer these sway bars with the 2013 C6 Z06 shocks. Also, whether it is a C5 or C6, coupled with the 2013 C6 Z06 shocks it makes a total different handling package. This package speaks for itself as we have many testimonials from many customers from whom we sold these to here on the forum!
To order, please call 484-334-8833 or go to the link below to order!
https://www.cultragfactoryparts.com/...-kit-c6z51bars
||--Genuine GM C6Z51 Sway Bar Kit--||
25919502 – Front stabilizer bar
10339124 – Rear stabilizer bar
10387838 – Front stabilizer bar bushings (2)
15241135 – Rear stabilizer bar bushings (2)
Complete kit front and rear is $257.95
Use part number c6z51bars on our website.
=&2013 C6 Z06 Shocks!
We sell the 2013 C6 Z06 shocks for $309.95. Many C5 customers ask us why we don’t recommend the 2004 shocks over the 2013. Many people also say that the C6 shocks are only developed for the C6. If you look at all of the basic suspension components between the C5 and C6, they are very much the same. The reason we don’t recommend the 2004 Z06 shocks over the 2013 C6 Z06 shocks is simply because of the price and customer feedback. We have many customers who have tried both sets of shocks and cannot tell the difference between the two, so why not purchase the lesser expensive set!
For the C5, not C5 Z06, we also recommend the C6 Z51 sway bar kit. The C6 Z51 sway bar kit coupled with the 2013 C6 Z06 shocks is our most popular suspension and handling upgrade for the C5.
https://www.cultragfactoryparts.com/...it-c6z06shocks
||--Genuine GM 2013 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) $309.95 total.
For the shocks on our website, use part number c6z06shocks.
The C6 Z06 shocks will work on stock C5’s and C6’s without modification.
Thank you,
Gene.
Greetings Friends,
C5 base 23.0 19.1
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
Thank you,
Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Place your order today!
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
Finally got my Z51 sway bars installed. Wow. what a difference love them. Thanks Gene
Greetings Friends,
We have the Z51 sway bars kit with the Genuine GM bushings for $245.53.
C5 base 23.0 19.1
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
To order, please call 484-949-2099 or go to the link below to order!
http://www.cultragfactoryparts.com/c...kit/c6z51bars/
Complete kit front and rear is $245.53
2013 C6 Z06 Shocks!
We sell the 2013 C6 Z06 shocks for $294.94 Many C5 customers ask us why we don’t recommend the 2004 shocks over the 2013. Many people also say that the C6 shocks are only developed for the C6. If you look at all of the basic suspension components between the C5 and C6, they are very much the same. The reason we don’t recommend the 2004 Z06 shocks over the 2013 C6 Z06 shocks is simply because of the price and customer feedback. We have many customers who have tried both sets of shocks and cannot tell the difference between the two, so why not purchase the lesser expensive set!
http://www.cultragfactoryparts.com/c...t/c6z06shocks/
Both sets of front and rear shocks (4) $294.94 total.
Thank you,
Gene.
Greetings Friends,
C5 base 23.0 19.1
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
2013 C6 Z06 Shocks!
Thank you,
Gene.
I have a 2005 Vette (non-Z51/Z06) and my front OEM end links are worn out. This looks to be the right time to upgrade my sway bars, and the Z06 shocks sound very interesting, but I have the F55 suspension I believe. Will the shocks work with this?
Yes, but since the 05 has the magnetic shocks you'll have to get the shock simulators or install a resistor in the system, to trick the computer into thinking the magnetic shocks are still installed. Other than that a direct bolt on.
So in other words I lose that feature? Do you think the swap is worth it?
Bump for a good vendor - I recently purchased a sway bar through them and it was very well packaged to prevent shipping issues! If youve ever had a swaybar go through the box during shipping, youll understand why packaging is so important.
base uses a ridiculously softer front spring but the rear is roughly the same
Shocks front and rear are different
Sways are different
Sways are different
Help
hello
First sorry for bad English
I'm from Brazil and I have a 2008 C6 Coupe Base and need suspension upgrade, I think too soft the original set.
This set would be ideal? What other option? Koni? Bilstein? With Z51 bars
thank you
thank you
Sways are different
Sways are different
are these springs hard to install? (the transverse springs) I don't think iv seen anyone selling them on here
Youll see a big improvement over the FE1 susepsnion.
Koni single adjustable and bilstein sports are also good choices that others have tried here
Time consuming but not difficult - there are plenty of writeups that folks have posted
Sways are different
Sways are different
Howdy Gene. I've got a 2006 base model with Centennial wheels (325 rear tires) along with the Z06 brake upgrade and F55 suspension.
What package would you suggest for complete sway bar upgrade and price at?
Deleted: Commercial posting
Supporting vendors pay for the considerable bandwidth charges on the Forum, making it free for the rest of us. In exchange, they get the privilege of using the Forum to market and promote their goods and services. Historically, we allow them to post in the generation sections and the regional sections to market and promote their products/services.
Forum members are welcome to sell a Corvette or Corvette parts they purchased for their own personal use. They also are welcome to use the Forum to purchase items for their personal use. Anything else is considered to be a commercial sale or a commercial purchase for the purpose of re-selling. Please check the sales rules regarding eBay sales and links:
http://forums.corvetteforum.com/foru...eir-parts.html
Members are not prohibited from mentioning it when they have a good (or bad, for that matter) experience with a non-supporting vendor. But such mentions cannot be so specific (logos, address, phone number, e-mail address, URL, price, part number, offer to send contact information via PMs, etc.) or so frequent that they become marketing and promotional references.
Only supporting vendors can post Group Purchase threads. Only supporting vendors are permitted to post threads to gauge interest in a product.
Members can include a mention of their personal businesses in their signatures or posts so long as the enterprise does not compete with an existing supporting vendor, is not Corvette-related and is not so detailed (logos, address, phone number, e-mail address, offer to send contact information via PMs, etc.) or so frequently appended to their posts that it becomes inappropriate marketing and promotion. The same applies on references to other Internet automotive communities.
For details and pricing on the site's supporting vendor program, contact the advertising team at Internet Brands through this link:
http://www.internetbrandsauto.com/contact
