C7 Vendor for Sale Exclusive forum for vendors to list C7 products, services and promotions.
New From Southern Car Parts…C7 Corvette Stingray Coupe Trunk Partition Available
Old 01-03-2015, 02:26 PM
southerncarparts
Supporting Vendor
southerncarparts's Avatar
St. Jude Donor '06-'07, '13, '15
Default New From Southern Car Parts…C7 Corvette Stingray Coupe Trunk Partition Available
Do you get tired of driving down the road and having all of your belongings in the trunk cargo area end up directly behind your head? Southern Car Parts is carrying on our tradition of the trunk partition for the all new 2014-2015 C7 Corvette Stingray. We originally created the Corvette trunk partition for the C5 Corvette and then C6 Corvette. Many Stingray owners were asking for us to create something for their C7 and we did. This trunk partition will easily slide into the cargo area and just rest in place, tightly against the roor latches.
In Stock Here: http://www.southerncarparts.com/corv...on-p-6612.html
The C7 Corvette Stingray trunk parition is designed so that you simply lay the partition down while the removable top is being stored. Best of all, this partition does not require any permanent modifications and can be removed in the matter of seconds. We've designed this parition to sit in place tight and will not move under hard acceleration or under hard breaking.
The C7 Corvette Stingray trunk partition is made out of quality 1/2" MDF board and is carpeted on all sides and on all edges for a nice finished look. This piece really looks like GM included it from the factory.
ALSO AVAILABLE C7 CORVETTE TRUNK VETTE TRAY
For the C7 Corvette Stingray. Are you tired of items sliding around the back of your Corvette with little usable or convenient storage space? If so, the Southern Car Parts VetteTray Cargo Organizer is for you.
VetteTray Available here: http://www.southerncarparts.com/corv...ay-p-5855.html
The VetteTray is sturdy yet lightweight weighing in at less than 1 pound. Our registered design is constructed of 2 inch High-Density foam which is factory cut and wrapped in matching black or dark grey carpet for a perfect fit and finish. Keeping weight in mind, the Vette Tray is made from Extruded Polystyrene foam and wrapped in black carpet that is a close match to the C7 carpet. If you are unhappy with your purchase for any reason, simply return it for a full refund.
- Each VetteTray comes standard with (2) Drink Holders and (2) 9 x 12in storage trays
- Perfect for holding cellphones, PDA's CD's, wallets or any other small items
- Required NO modifications to your Corvette
- Does not come loose with hard braking or acceleration
The following 2 users liked this post by southerncarparts:
blkvet6 (06-03-2018), Kimonord (02-15-2017)
Old 01-16-2015, 07:32 PM
Stan0324
Stan0324's Avatar
Asked this before with no response, so here it goes again.
So you have emblems, Z51, Cross Flags or the Fish that will match up in size and stay on for this partition ? I think I bought my C6 GS one from you that had the "Grand Sport" name enclosed in the center of the partition.
Thanks
Old 01-16-2015, 09:47 PM
southerncarparts
Supporting Vendor
Thanks
Sorry. We do not.
Old 01-17-2015, 02:15 AM
beltfed21
beltfed21's Avatar
Question, will the partition and tray fit together, or does having one exclude the other? Both would be good for longer trips.
Old 01-20-2015, 01:24 AM
beltfed21
beltfed21's Avatar
Hello..... Still waiting on an answer to my question......
Thanks!
Old 01-29-2015, 11:08 AM
southerncarparts
Supporting Vendor
They do fit together.
Thanks,
Dave
Old 02-10-2015, 05:10 PM
Roadrogue
Roadrogue's Avatar
The tray is an excellent idea. I'm ordering one now.
If you use the partition with it how do you reach the tray? Just asking.
Old 02-10-2015, 05:16 PM
Roadrogue
Roadrogue's Avatar
Maybe it's me but I couldn't find on your website where to specify black. Please advise.
OK, I looked again and it seems that it only comes in black. Sorry for my confusion.
Old 02-23-2015, 09:10 AM
southerncarparts
Supporting Vendor
The partition will be behind the tray so it doesn't interfere at all.
Thanks,
Dave
Old 03-17-2015, 10:26 AM
southerncarparts
Supporting Vendor
Old 03-17-2015, 12:23 PM
jsimp413
jsimp413's Avatar
I have a Lloyds mat in the back. Does the extra thickness have an effect on installing either the tray or partition?
Old 04-02-2015, 10:42 AM
southerncarparts
Supporting Vendor
No, it won't cause any problems.
Thanks,
Dave
Old 05-17-2015, 06:02 PM
sailgunner
sailgunner's Avatar
Seems like a solution to a non existent problem.
Old 06-03-2015, 06:54 AM
robertson2900
robertson2900's Avatar
https://www.corvetteforum.com/forums...ies/iagree.gif
Old 06-03-2015, 06:57 AM
robertson2900
Default Amen
Old 08-14-2015, 07:25 PM
VNV Doc
VNV Doc's Avatar
Default Trunk partition
Does this partition come in grey? What about the VetteTray? Does it come in grey also? I have a grey interior and black just won't work. Thanks.
Old 10-18-2015, 04:27 PM
southerncarparts
Supporting Vendor
This is the only color currently offered..
To New From Southern Car Parts…C7 Corvette Stingray Coupe Trunk Partition Available
Old 12-23-2015, 04:57 PM
Patches
Support Corvetteforum!
Patches's Avatar
"The C7 Corvette Stingray trunk parition is designed so that you simply lay the partition down while the removable top is being stored."
Does this mean you have to lay the partition down while stowing the top and then set the partition back in place once the top is secured in the rear?
Old 01-14-2016, 05:17 PM
southerncarparts
Supporting Vendor
That's right!
Old 01-23-2016, 09:28 AM
plasboy
plasboy's Avatar
What I would like to see is a partition made with the vertical portion all the way forward. Not really worried about storage but would like noise reduction.
Quick Reply: New From Southern Car Parts…C7 Corvette Stingray Coupe Trunk Partition Available
