Intermittent Air Bag light & Recall
I have a 2008 with 19,000 miles. Just started getting the dreaded intermittent air bag alert. Also just got my headlight jumper wire recall letter.
My question is, when I take the car in for the recall, if I were to ask them to take a look at the airbag issue, would I be charged for the inspection and possible easy fix if it is the bad connector issue?
I dislike the idea of allowing GM to mess with my car and worse, I hate paying GM for the repair of a safety issue, which should have been handled by a recall already.
The truly great news is this is the first problem I have had with my Vette during the seven years I've owned it.
Thanks for your time.
Airbag is the yellow connector under the rear of the driver seat, just needs a zip tie; search here, and do NOT let the dealer diagnose it; you will pay a bunch of money and have a messed up car.
I am undecided on letting the dealer do the headlight fix; on the last recall (active handling telescopic column connector), there were more problems created than solved.
Race Car Tech
Here is a pic
Thanks guys.
I'll go ahead and check the connectors. I have never taken the car to the dealer since I bought it, and I really hated the idea of starting that practice now. But I figured if I could get two things done at the same time: then maybe.
But I won't plan on taking it in for either issue.
Thanks for the great pictures, encouragement, and confirmation.
Frank
Frank
Received 2,051 Likes
St. Jude Donor '13
Airbag light can be a connector, as others mentioned. On our car; it turned out to be a bad wire in the seat belt pre-tensioner, the stalk that has the female end of the seat belt buckle. Driver side, in our case.
I'm currently having the same problem on my '06. I took it in for the headlight fix, and discussed the problem. Sometimes moving the seat forward/back, or adjusting its height, will make the light go out. So I'm leaning toward the connector under the seat as the first place to check. I've already had the power connector for moving the seat come apart.
The service manager said if the light is on, the air bag will not work. Is there any way to determine if anyone has been hurt or killed, as a result of the air bag not working?
I will take my 08 convertible to an Evansville dealership for the headlight warranty. My airbag light started coming on last fall(yellow connecter I guess). Did they do a good job on the headlight fix? Sorry about the highjack of thread. Thanks blk08vert
Driver side seat belt had been retracting slowly so I cleaned it (soaked in water with laundry detergent then cleaned with upholstery cleaner with a brush). The belt now retracts and the light goes off as it should. I think the slow retracting belt (had to feed the belt by hand) was interfering with the pretensioner.
So far so good!
Dave
As far as anyone being injured by an airbag not working, you are more likely to be injured by the airbag if you are not wearing a seat belt.
Even though airbags save lives and reduce injuries, they can also cause cardiac and pulmonary injuries and death, especially if the driver or passenger is not wearing a seatbelt.
https://www.amstat.org/newsroom/pdfs...ntsAirbags.pdf
Air bags alone do little to prevent injuries.
The injury-reducing effectiveness of the air bag alone, without the use of safety belts, was estimated to be 18 percent, and was not significantly better than being unrestrained.
...Frontal crashes are where the air bag is most likely to deploy, suggesting that deployment may result in increased risk of moderate injury in some situations.
You really want to see that explosion just inches from your face?
Recall letter for intermittent air bag light?
I received a letter from GM for my 2008 maybe 3 months ago. I can't find the letter now, but I could swear it said there was a recall for it.
I called the service department today to schedule an appointment for that and two other recalls, but they tell me they see nothing about it.
Anyone else receive the letter about the intermittent airbag light? Or was that letter for something else.
Had to do with wire harness connector coming loose and causing airbag light to be illuminated.
Update: Now in possession of the letter dated May 2016. Has code number 15643. I think this is the same subject as discussed above.
I had originally used the zip tie fix on my 2013 seat but the problem returned some 3 or 4 months later. My wires were really chewed up outside the plug as it looks like they were crushed in the seat track at some point.
Steve
My understanding is it is only fixed if the light is on. I don't believe it is a general recall but if you have a problem within 10 years they will fix it.
I just had the light come on, after smog test. Turns out, the smog guy is 6' 6" 250+lbs.
He had to move the seat all the way back and all the way down to get in the car, causing the connector to rub the carpet. I removed the seat, installed 2 ties per photo. Hope it is fixed. I got the letter dated May 2016 extending this issue warranteed 10 years. Dealer says it is not a recall.
Thank you corvetteforums.
Roger
Roger
I notice when the seat is down and all the way back, it comes close to the connector.
Maybe remove a piece of carpet to allow clearance for the connector?
They said they had to order parts to affect the repair. So that could mean they indeed had to change something. But I don't know.
As you probably found, there is some excellent advice in this thread regarding a DIY repair.
I had this problem with my 06. Unfortunately GM would not pay for the fix. Fortunately i had a bumper to bumper after market warranty. The problem was the seat belt pretensioner which the tech took about 10 minutes to replace. The cost for the repair was well over $400.00. Lucky for me i had a $100.00 deductable.
Navigator
