Build sheet
Build sheet
picked up my c7 at the factory almost a year ago never found the build sheet got everything else is it hidden somewhere in the car ? anyone know where to look ?
I don't know where to look either, don't know if they still tuck it away like they used to. You can order one from the Corvette Museum. Factory delivery? You mean Museum delivery? I did the Museum delivery and asked for my build sheet right then. Got it laminated, too, along with the "window sticker". I also found 2 build sheets in the stuff the Museum collected when they prepped the car, one called 17-CP Cockpit and one called Corvette Doorline. These are usually taped to the car during the build on the assembly line. Pretty cool, to me anyway.
It arrives to the dealership in the car and is usually tossed out by most dealers as junk. If you order one, it's smart to be there when it comes off the truck to collect the various documents that the prep crew normally tosses. A few dealers recognize the value to an individual that may prefer to keep them and set them aside for you.
Here are the ones I gathered off the line last week.
Top left, overall "true" build sheet: This lists the options, dealer, general manufacturing information, similar to the window sticker. This is the one that should get sent with the car.
Top right, towveyer build sheet for drive line.
Left center, main chassis line build sheet.
Right center, detailed chassis line build sheet.
Bottom left, door assembly build sheet.
Bottom right, cockpit build sheet.
There were other small papers that traveled with the car as it went down the line. I did not get them all.
17-cp cockpit build sheet
The picture of your 17-CP Cockpit build sheet for Z06 is chopped off at bottom
Can you take picture of sheet and REPOST
or
Whats the number for the TUNER & PDR
ALSO
the SEAT BOLSTER SWITCH & BAT WING
all part of Group E
Thanks
or
ALSO
all part of Group E
Thanks
