How-To: Remove/Clean/Replace the Fuel Rail & Injectors
Old 03-01-2015, 03:44 PM
Theta
Theta's Avatar
St. Jude Donor '14-'15
Default How-To: Remove/Clean/Replace the Fuel Rail & Injectors
The following How-To covers the explanation of how to Remove/Clean/Replace the Fuel Rail & Injectors and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
Theta
Theta's Avatar
Removal:
Theta
Theta's Avatar
Cleaning / Inspection:
Theta
Theta's Avatar
Install:
Old 03-01-2015, 04:43 PM
T/A KID
T/A KID's Avatar
Awesome....from the looks of it they can be unplugged from the connector in the back on each side. and they entire rail/injectors/harness can come out together??
Seems like transferring from one head to another will be easy.
Old 07-27-2016, 05:33 AM
RJW
RJW's Avatar
Location: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
does anyone know if the the fuel lines going to the fuel rails need to be discarded? If so, anyone have part numbers?
thx
Old 07-27-2016, 08:02 AM
Higgs Boson
Higgs Boson's Avatar
Received 2,378 Likes on 1,238 Posts
one time use only. part number is floating around here somewhere.
Old 07-27-2016, 02:28 PM
RJW
RJW's Avatar
St. Jude Donor '08
called a gm wholesaler, he couldn't find it, but the low pressure feed hose ended with an 8, so googled number ending with a 6 and voila !!
gm 12618336 hardline that connects both fuel rails to the 12618337 line to pump.
It is unreal how many discarded parts and SPECIAL ($$$) tools are needed, even to change 1 DI injector
thanks every one for these threads
Old 11-03-2019, 11:21 AM
emperors61
Support Corvetteforum!
emperors61's Avatar
The latest part numbers are 12677002 and 12677004 for the disposable fuel lines that GM calls "fuel feed intermediate pipe position 1" and "fuel feed intermediate pipe position 2." Also the part number for the "fuel feed pipe" is 12677005.
Old 01-03-2021, 08:56 PM
golfster
Navigator
golfster's Avatar
Does it take a special tool to remove the wiring harness? Not injector. Just the harness. I push up the button but the wiring connect doesn't just slide out.
To How-To: Remove/Clean/Replace the Fuel Rail & Injectors
Quick Reply: How-To: Remove/Clean/Replace the Fuel Rail & Injectors
