C4s for Sale/Wanted Private Classifieds: Used C4 Corvettes For Sale as well as Modified or Stock Corvettes
89 Vert 6 speed 383 lpe super ram copy
Old 03-24-2015, 12:03 PM
lozer
lozer's Avatar
Default 89 Vert 6 speed 383 lpe super ram copy
Located in Rohnert park, Ca
Selling to pay for my Daughter to get into Karting.
9,000$ obo
I have almost all receipts for parts and work performed.
Inspected and approved for NASA HDPE
Engine: copied Lingenfelter 383 super ram build EST. 440hp 480tq
Engine work and head rebuild machined by Metcalf machine on 3-13
Tuned by pcm4less
Wideband o2 sensor
Shift light
adjustable rev limiter
Hooker headers connected to stock exhaust with 50 series flowmasters
Fresh 383 with less then 5k
Forged pistons
Eagle crank
Arp studs and bolts everywhere
All fresh bearings
Line bored, balanced
7/16 I beam scat rods.
Crane gold roller rockers
Lingenfelter LPE219 cam with fresh roller rockers
Ported and polished 89 113 aluminum heads with 3 way angle grind
enlarged valves 2.00/1.56
Canton road race pan
HV Melling's oil pump
58mm throttle body
Polished and port matched edelbrock intake.
Spec Lightweight flywheel
Spec stage 1 clutch
Underdrive pulleys
Walboro 255 fuel pump
Suspension
Front offset LCA bussshings
Z51 front spring lowered
Qa1 single adjustable shocks
84 z51 rear spring
Stock 89 very sway bar
Bankski rear toe, camber rods
Vans Steele trailing arms
Dana 44 stock rear end
Aligned and corner balanced by TFB performance.
Brakes
Hawk hp1 on all 4 corners
Big stock brakes
NASCAR style brake blower set up with switch
Brake proportioning spring with new booster and master
Wheels and tires
It currently has c5 corvette wagon wheels in 18x9.5 with almost new direzza star specs
but it could come with additional sets of rims with tires.
Interior
Auto power rollbar
Kirkey road race seat
Interior is currently in the car.
Has both stock seats
A/c is working, power everything
Lightweight battery relocated to behind passenger with cut off switch
2 sets of rims with direzza star specs 17x9 89 stock set
C5 wagon wheels 18x9 also
All original parts are still with the car and will come with it.
The negative stuff
The car will be sold as is as a track car and no smog will be provided. Although it can be smogged easily by installing the original headers and downpipe (included) and a new cat.
Rear window has a crack in the plastic"
Original driver seat has wear in the left bolster
the hood is cracked on the edge closest to the driver side.
I'm sure I'm forgetting some stuff but just ask
Old 01-17-2016, 04:19 PM
lozer
lozer's Avatar
bump still for sale. make a reasonable offer or trade for something classic.
Old 04-18-2016, 03:54 AM
lozer
lozer's Avatar
price drop to 6000$ need to sell it
Old 04-18-2016, 09:08 AM
wyaif
6th Gear
wyaif's Avatar
Digging the wheel setup. That is a serious piece of hardware for $6k glws
Old 04-18-2016, 07:19 PM
lozer
lozer's Avatar
currently has full interior, stock seats and pioneer stereo install.
Old 04-24-2016, 12:17 PM
Dueller
Dueller's Avatar
New member here...admin has not enabled pm privileges yet. Sent you a visitor message. Interested kin this car.
Thanks
Jim
Old 04-24-2016, 12:19 PM
Dueller
Dueller's Avatar
Visitor msg sent
Old 07-27-2016, 03:28 AM
345HP87SSAC
345HP87SSAC's Avatar
Did this sell?
To 89 Vert 6 speed 383 lpe super ram copy
Quick Reply: 89 Vert 6 speed 383 lpe super ram copy
