Sponsored by: GEM Motorsports
Ceramic Coated Corsa X pipe
Old 06-29-2015, 08:30 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Default Ceramic Coated Corsa X pipe
I always get my exhaust coated and now offering it to the community. I can have them done in black or silver like mine
Link to coated version
http://c7z06owners.com/store/z06-exh...sa-x-pipe.html
They did brackets also
Old 06-29-2015, 11:41 PM
C7_Z06
C7_Z06's Avatar
How much for the coating?
Old 06-30-2015, 04:16 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Old 06-30-2015, 04:28 AM
Z06Ronald
Z06Ronald's Avatar
Whew, that's cool in more than one meaning! I should have done something like that as well (for my C6 Z06).
Is your X-pipe coated inside and out?
Old 06-30-2015, 11:48 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Yes fully coated
Old 06-30-2015, 12:38 PM
ovrebo1
ovrebo1's Avatar
Does it ever make the any car louder?
From my understanding the heat meeting the air is what produces a lot of the sound we hear and since the coated exhaust tubing is now transferring the heat out the rear rather than radiating it under the car I would think theoretically it would be slightly louder
Old 06-30-2015, 12:45 PM
jvp
Support Corvetteforum!
jvp's Avatar
Received 3,803 Likes on 1,143 Posts
"Ask Tadge" Producer
Planning on doing the manifolds, too?
Old 06-30-2015, 01:23 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
I've installed 6 on local customers z06's. Yes louder for sure. Do to my other car blowing up am not doing headers. I will be removing stock exhaust manifolds and then coating them also
Old 06-30-2015, 01:28 PM
ovrebo1
ovrebo1's Avatar
Cool. That was always a theory of mine, but was never able to test it by hearing a non coated system first to compare it to.
I worked for a hot rod restoration shop where we would tig an entire system up from scratch and then just immediately send it off to JetHot.
Old 06-30-2015, 01:54 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Since headers are stainless steel I'm thinking about making a bolt in deal from oem manifolds to mid pipe with no cats
Old 06-30-2015, 03:30 PM
C7 x 2
C7 x 2's Avatar
Your thoughts on wrapping the x-pipe with header wrap? I will be getting the Borla x-pipe and have thought of doing this just to control the heat from the tunnel & floor. Since the wrap is supposed to control the heat even more that the coating I wonder what that would do to the sound?
Old 06-30-2015, 06:22 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
do the coating when doing the inside it also helps exhaust flow faster out which in turn helps performance.
Old 06-30-2015, 08:17 PM
johnglenntwo
johnglenntwo's Avatar
Dyno?
Old 07-01-2015, 07:20 PM
johnglenntwo
Default Okay!
Originally Posted by johnglenntwo
Dyno?
Lets guess ~10hp, better throttle response, and losing heat!
(A good MOD I have on my car, but, mine is wrapped!)
Old 07-02-2015, 06:05 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Not sure about dyno but I will be removing my manifolds and cat pipes and getting them coated
Old 07-03-2015, 04:56 PM
sixthsense114
sixthsense114's Avatar
what is the heat resistance on the ceramic coating?,I would be interested in a similar setup (black coat) instead of silver. Do you plan to do the manifolds/catpipes inside out , does it need any cleaning or prepping?
Is there any heat-cure cycle to follow immediately after coating.
This will definitely help in lower hood temperatures as the coating will act like an insulator, not sure how much stress it would add to the metal itself.
please bear with me for asking so many questions
Old 07-04-2015, 12:36 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Good up to 2500 degrees.
I will be porting my manifolds and doing them along with the cat pipes.
No heat cycle just put it on and go
To Ceramic Coated Corsa X pipe
Old 07-05-2015, 02:44 PM
Kracka
Kracka's Avatar
Received 5,713 Likes on 2,920 Posts
Very nice! I'm wishing I would have gotten my Borla X-pipe coated. I'm tempted to pull it off and get it done now!
Old 07-29-2016, 03:39 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
another one shipping to a customer tomorrow.
Old 07-29-2016, 08:20 AM
Kracka
Kracka's Avatar
Very nice! I am tempted to pull mine off this winter sometime and get it coated. Great to see a vendor offering this.
Quick Reply: Ceramic Coated Corsa X pipe
