TPIS Miniram II for sale
Mini for sale. Standard Felpro 1204 ports. Never ported . Will port to 1205. Very clean. Water neck, linkage brackets, fuel rails and some 6 AN lines that may or may not work with your car. I had an Edelbrock base and TPIS big tube runners and the best ETs I could get were 13.teens. Bolted on the Mini and went 12.80, second pass.
This intake had a casting flaw that TPIS welded up before I bought it. YOu can see it on the bottom side. On the top, if you look real hard, behind and below the thermostat you can see where it was repaired. Cosmetic flaw has no other effects.
$750 shipped.
$750 shipped.
This is what I have, less the 12 Manifold bolts.
http://tpis.com/parts/view/37
http://tpis.com/parts/view/33
Early 2014, the local drag strip shut down. Last summer I removed headers, heads and intake and put it back stock since I had no place to race. Now the track has a new owner, so if I dont get a good price for the mini, I will put it back on. Easiest .3 I have ever gotten.
Thanks for the bump. TPIS sells well designed parts. My TPIS headers were the best headers I have ever had and this intake not only gets you the power, the install is very simple. The AN lines included worked great on an 87 and a 90.
TPIS mini ram II
$750 shipped.
$750 shipped.
lotus1964
