Halltech intake with Nomex
Hey guys, my new Halltech (Gen 2) intake will be here on Monday. I also have the 17" Nomex sock (sleeve) as well. Here's my question... Would it not be a good idea to wrap the entire intake tube with a reflective heat tape/wrap BEFORE I install the Nomex sock? Seems like it would really help keep the heat at bay and since it's going to be covered by the Nomex anyways, it would look decent.
Thoughts. Thanks!
Thoughts. Thanks!
I think this is a good question.
Thoughts. Thanks!
Thoughts. Thanks!
lotti (09-12-2015)
Of course it would. Any insulator will reduce heat transfer. The more the better, at the expense of weight. It's very difficult to get the main coolant hoses to not directly touch the intake tube... this is the main difficulty in the Halltech installation, in my opinion. I'm hoping to readdress it when I swap mine out for the Gen 2. Wrapping will definitely help reduce intake air temps as long as the material used won't be adversely affected by the heat or touch anything that burns it.
Supporting Vendor
St. Jude Donor '09
No additional heat shielding is necessary for the intake tube. You could get some aluminum ceramic type for the airbox where it faces the engine.
All Nomex orders ship today unless you ordered it with your Stinger-RZ order, which will ship installed on the intake.
I will have installation instructions later today. Super Simple.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
Jim how do I order this? I haven't had a chance to install my gen 2 so it will be better if I can do it all at the same time.
Herman
Supporting Vendor
St. Jude Donor '09
You can put whatever you want on the intake tube, but I doubt you will be able to get the sock over the tube. It has Spandex (17%) but it is very tight.
Supporting Vendor
St. Jude Donor '09
Supporting Vendor
St. Jude Donor '09
Nomex has excellent heat protection as well as flame protection
You have all seen the spark plug Nomex shields. Here is an article on automotive uses.
http://www.dupont.com/products-and-s...ark-plugs.html
Would you try the flame test we did on your arm? 500 to 600 degrees, and only +10 degrees rise in temp. That would not have occured if the Nomex hadn't finally burned away. We had done 6 previous tests.
Supporting Vendor
St. Jude Donor '09
Propane Flame Temperature is 3623F in air
Boy was I underestimating the flame temperature of propane.
So when my arm was inside the plastic intake tube, with a very thin Nomex barrier, it was resisting 3,623F temps. The temperature did not increase at all during the test until the Nomex finally gave up the ghost.
It was the seventh test that day in the same spot, and the Spandex may have been the culprit in it finally going to the grave. Interestingly the plastic melts at 280F and it was unscathed after the test.
Hot air guns reach 1100F.
A propane torch is a tool for burning the flammable gas propane (C3H8). The maximum adiabatic flame temperature a propane torch can achieve with air is 1,995 °C (3,623 °F).
Supporting Vendor
St. Jude Donor '09
I have one going to a racer who will do before and after testing.
We offer 100% money back guarantee if this does not help stave off heat soak from the radiator fan.
Typically we seen 140F underhood temps. It will be interesting to see some before and after testing of the IATs. It was easy to illustrate the heat insulation benefits using temps that will never be seen under your hood.
Supporting Vendor
St. Jude Donor '09
BTW. Those that have purchased our CKNZ (Carbon, Kevlar, Nomex IIIa) Z06 system, the Nomex is actually integrated into the middle of the outer and inner layers) We have a patent pending on that design.
The Nomex installed:
