FS: Carbotech performance brake pads including low dust
Supporting Vendor
St. Jude Donor '11,'13
We have all compounds in stock ready to go. Please contact me at 216-780-8825 to order or with question about your specific application by PM or email at sales@ampdautosport.com or purchase online at http://ampdautosport.com/ and use promo code z28 at check out and save $$. You can also call me to order at 216-780-8825 and still save 5%.
Brake Compounds
Carbotech™ 1521™
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
Carbotech™ AX6™
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1000°F + (10°C to 537°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn't recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as a race compound in most applications.
Carbotech™ XP8™
A high torque brake compound with a wide operating temperature range of 200°F-1250°F+ (93°C to 676°C+). Carbotech™ XP8™ is the first of our racing compounds. Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Perfect for track day use with any tire and can still be driven safely to and from the track. Carbotech™ does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. Carbotech™ XP8™ is a great compound on the front & rear of most open wheel and sports racers.
Carbotech™ XP10™
When Carbotech™ unleashed the XP10™ to the general public it immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1475°F (801°C). XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP12™
Another highly successful XP™ series compound with an excellent initial bite, torque and fade resistance over and above the XP10™ compound. XP12™ has temperature range of 250°F to 1850°F+ (121°C to 1010°C+). The XP12™ has that excellent Carbotech™ release and modulation that has made all other Carbotech™ compounds so successful. The XP12™ is more rotor aggressive than XP10™, but compared to the competition the XP12™ is still very rotor friendly. XP12™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP20™
The latest iteration of the highly successful XP™ series of compounds. XP20™ is a step up from the highly successful XP16™ compound. With an extremely aggressive initial bite, linear torque curve and excellent fade resistance the XP20™ is another major step in progression of the highly successful XP™ series line of compounds from CarbotechCarbotech™ compounds so successful. Carbotech™ XP20™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP24™
XP24™ is the pinnacle compound of the extremely successful XP™ Series of compounds engineered by Carbotech™. This compound is based on the same fundamentals that exist in all other Carbotech™ formulations. XP24™ has even more initial bite, more overall bite, and more torque along with the most linear torque curve we have ever offered. The thermal characteristics are of the highest Carbotech™ offers along with one of the highest coefficient of friction ratings offered by anyone in the braking industry. This compound is the longest wearing compound Carbotech™ offers as it was originally engineered for endurance applications at the highest pro racing levels. This revolutionary new compound has been extremely successful with open wheel, closed wheel, sprint and endurance applications. XP24™ has a temperature range of 400°F to 2000°F+ (204°C to 1093°C+). Carbotech™ XP24™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise along with the necessary heat required to work properly.
Brake Compounds
Carbotech™ 1521™
Carbotech™ AX6™
Carbotech™ XP8™
Carbotech™ XP10™
Carbotech™ XP12™
Carbotech™ XP20™
Carbotech™ XP24™
Supporting Vendor
Give us a call 216-780-8825 and we can recommend the compounds that will be perfect for your front and rear pads. Assuring that they perform together with optimum effectiveness
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Friday You need pads or have questions give us a shout.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Brake Pads Street or Track Amp’D autosport has plenty of Carbotech compounds ready to go. Take 5% off your order when using promo code z28 at check out or call us direct at 216-780-8825 to order. Pre bed option is also now available for all Carbotech brake pads. Looking forward to hearing from you soon. Please call or email us with any questions.
Direct link: http://ampdautosport.com/
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Plenty of Carbotech pads ready to go.... Use promo code z28 at check out or call us direct at 216-780-8825.
http://ampdautosport.com/brake-pads/corvette/
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
To The Top...
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Open Saturday gives us a call if you have questions and of course orders 216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Thank you all for the orders we appreciate it. Keep the phone calls, Emails, and PM’s coming we appreciate the opportunity to work with all of you.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Use promo code z28 at check out or call us direct at 216-780-8825 Open till 9PM or 24/7 at http://ampdautosport.com/brake-pads/corvette/
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Open Saturday give us a call and as always 24/7 at http://ampdautosport.com/brake-pads/corvette/
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
I do not do Black Friday sales. I offer same discount to every member regardless of the day. Use promo code z28 at check out http://ampdautosport.com/brake-pads/corvette/ or call 216-780-8825 to order.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
We combine superior customer service, speedy delivery, and the highest quality pad on the street or track . We can also accommodate special orders for any of Carbotech's compounds. Contact sales@ampdautosport.com for more information PM me or call 216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
To order use promo code z28 at check out or call us direct at 216-780-8825. If you have questions leave them here or feel free to call, email or send private message.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Happy Friday if you are looking for new brake pads or have questions leave them here or call us direct at 216-780-8825. If you would like to order pads please visit http://ampdautosport.com/brake-pads/corvette/ or just call us at 216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
archfarseer (02-07-2018)
