Transmission internal shifter centering spring
So the story I bought my FRC this fall knowingly with the shifter not being able to center itself. the car had a mgw shifter in it that was pretty stiff so I swapped it out with a c6 shifter thinking maybe the tension was just too much for the centering spring to overcome... well this was not the case.
Since the car is parked for the winter where I have access to a lift so I went ahead and dropped the transmission to address this issue once and for all. After getting everything on the ground I figured I'd just go ahead and order the new spring and then split the trans when it came in. Well it turns out the spring was discontinued by GM in 2013 and I cannot find one.
What are these companies that rebuild the corvette t-56 using to replace these springs or are they just reusing them? Is there aftermarket reproduction options out there?
For reference the spring is #46 in this diagram:http://www.wholesalegmpartsonline.co...rimLevel=25296
Tech guys generally read here also. Have you contacted Cultrag?
I have not called Cultrag. I have looked to see if they have it in their parts diagrams but I am only finding whole transmission assemblies in their online parts diagrams.
Were you able to resolve this issue? I currently have my trans pulled out of my 2000 FRC as well and want to fix the centering issue. 1-2 springs back to center, but the 5-6 position does not. It drives me nuts.
T56 transmission
HI guys if use have not got your answer to the t56 transmission spring. use might want to call Jason at Tx drive Train he rebuild them or give you the advise you need. and he has parts on hand. his shop number is 817 757 7300 he will get back to you. good luck, Had my t56 rebuilt last Aug awesome job,
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If Gene Culley doesnt have it, you can also call Rick Kim RKT56
http://www.rktperformance.com/ (301) 257-0930
RKT Performance
5400 Yukon Court,
Suite 400
Frederick, Maryland 21703
The man is amazing with drivetrain issues. He rebuilds Transmissions and differentials to perfection.. He may have your answer.
Bill
RKT Performance
5400 Yukon Court,
Suite 400
Bill
Gene Culley (01-25-2017)
I did much research last night and have narrowed it down (I think) to the shifter guide block that rests above the shift guide plate at the top of the transmission.
http://www.superchevy.com/how-to/070...uild/#photo-35
I will be pulling off the rear tailhousing and seeing if I can get to it without too much reassembly. My theory (could be wrong) is that the detent ball/spring is binding up somehow and needs to be diassembled and cleaned.
