C6 Zr1 Carbon Fiber Side Skirts **BLEMS** Hand Laid/Vacuum Infused
Former Vendor
Blem #4 (Handlaid 3k 2x2) $500 shipped This one doesn't have much bubbles at all just the little ones that you see in the picture and it is only the driver side. The passenger side is clean so are the flaps.
Blem #6 (Vacuum Infused) $300 shippedThis one was made with 3K carbon fiber first layer and woven fiberglass for the last two layer giving you a very light and highly flexible part. The twills do not have any blems in them the only thing the makes the part a blem is it does not have clear and little epoxy on the front end of the passenger side skirt.
Blem #8 (Vacuum Infused) $300 shipped This one is made like blem # 6 and 7. The clear is good, no scratches, but the again has the same bridging as 6 and 7 just a little more and the flange on the driver side skirts is cut deep but still will be able to install.
lawyered (03-10-2016)
I'm very interested in the parts does it come with everything to install and do u have a pic of what they look like on a car??
bradgarvin@gmail.com
Former Vendor
Former Vendor
Yes we do. Price ranges depending on the blemish itself. I currently have one that has very minute air pocked along the edge where the skirt meets the rocker panel they will not be visible at all once they are installed. The skirts do come with the flaps which only the drive side has blemishes, also has air pockets. The good ones normally go for 699 shipped. I can get you this kit for 625 shipped. They also come with the hardware need to install and instructions.
Former Vendor
These items do not have clear coat they are made with UV protected Epoxy. Some of these skirts had rough spots on them so we just sanded them a little in some parts which took the shiny finish off it can be easily polished to a shine again. In the description of the items states that they are not polished but the finish is very smooth.
Former Vendor
Former Vendor
Former Vendor
