Sponsored by: GEM Motorsports
C7 Z06 Main Cat Delete Kit
Old 03-30-2016, 01:00 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Default NORCAL SS C7 Z06 Main Cat Delete Kit
MY CAT DELETE KIT FITS
BOTH STICK SHIFT AND AUTOS
INDEPENDENT DYNO RESULTS
DYNO
The OEM manifolds flow well on the z06 but the kinks in the system are the main cat pipes inlet/catalytic converters and also the mid pipe.
In stock ready to ship
$739 shipped to the lower 48 states
3" stainless steel
FULL 304 STAINLESS WILL NOT RUST LIKE OTHER CAT DELETE KITS OUT THERE!!
Bolt in deal
Replaces oem pipes from manifold exit to midpipe entry
Pipes are farther away from oil cooler/lines to keep temps lower
Ceramic coating is optional
OFF ROAD USE ONLY
I can set you up with a paypal bill or you can shoot me a paypal payment tony@tbssowners.com
I can also offer a bolra mid pipe to make it a bolt in deal which is $450 shipped. On a customers car where I deleted the main and rear cats was a solid 18 rwhp gain/21 tq.
On a z06 NO TUNE long tubes headers make about 20 rwhp the gains you see come from tuning which voids the warranty. So you can do my cat delete kit and since your not touching the tune at all (and I've had yet to hear a car blowing a engine up due to taking off the cats) its no biggie because you can swap back.
Oh and be prepared to have a race car sound in track mode. It will be loud but due to keeping stock mufflers with valves closed will be perfectly fine and mild.
Note IF YOUR NOT TUNING YOUR CAR YOU WILL NEED 2 BIG DADDIES GARAGE 90 DEGREE 02 SIMULSTORS FOR BOTH 02 SENSORS THAT ARE AFTER THE MAIN CATS. THIS WILL PREVENT A CHECK ENGINE LIGHT
VIDEO OF IT IN ACTION
INSTALL (I highly recommend getting the corsa x pipe at same time which I can set up)
1.Disconnect battery
2.Remove tunnel brace
3.remove X-pipe
4. Unbolt engine mounts from cradle
5. Support engine
6. Lift engine
7. Unbolt cradle (6bolts)
8. Remove bolts from flange
9. Install off-road pipes
If you dint want to lift engine you can remove the studs that are on manifolds and replace with these
https://m.ebay.com/itm/10-M10-1-5-x-...&ul_noapp=true
The following 3 users liked this post by NORCAL-SS:
Blvdbrawler (08-05-2016), georgiadawgs (05-03-2017), Mikec7z (08-13-2018)
Old 03-30-2016, 01:50 PM
Toilets
Toilets's Avatar
Originally Posted by NORCAL-SS
After months of sending my oem test pipes out to different places finally have a go on this exhuast setup. The OEM manifolds flow well on the z06 but the kinks in the system are the main cat pipes and also the mid pipe.
  • $699 plus shipping
  • 3" stainless steel
  • Bolt in deal
  • Replaces oem pipes from manifold exit to midpipe entry
Check engine light will come on but car will run fine. They sell cat simulators online so you can try those to take it off
I will also offer a corsa mid pipe to make it a bolt in deal which is $539 shipped. On a customers car where I deleted the main and rear cats was a solid 15-18 rwhp gain across the board with no tune. Also since the pipes stay away from the oil/cooler lines and you can get the pipes coated it will keep temps lower.
Very easy install which will save hundreds on labor vs doing a long tube kit. On a z06 NO TUNE long tubes headers make about 20 rwhp the gains you see come from tuning which voids the warranty. So you can do my cat delete kit and since your not touching the tune at all (and I've had yet to hear a car blowing a engine up due to taking off the cats) its no biggie because you can swap back easy...where as headers you will be spending hours.
Right now its about 3-4 weeks out after I give the green light so if your interested just post up and I will add you to the list
CAT DELETE KIT
1) NORCAL SS
I'm in. Just tell me where to PayPal
Old 03-30-2016, 04:02 PM
rob62
rob62's Avatar
Received 1,733 Likes on 874 Posts
You should test and sell those "cat sims" with it. If they work, that is.
OLD_GOAT (05-30-2016)
Old 03-30-2016, 04:07 PM
fasthwks
fasthwks's Avatar
Put me on your list please
Old 03-30-2016, 04:44 PM
jdmdohcpower
jdmdohcpower's Avatar
I would be interested and would like to hear how it sounds if possible. +1 for the sim. Only interested if the CEL is not on all the time.
Old 03-30-2016, 07:30 PM
ccarnel
ccarnel's Avatar
I'm in on these, how do I get on the list?
Old 03-30-2016, 07:39 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
I will update first post tonight with your guys names
Old 03-31-2016, 02:48 AM
OH THREE Z
OH THREE Z's Avatar
2018 C4 of Year Finalist
Im in.
I agree that it would be nice to have a cat sim option that has been vetted.
Old 03-31-2016, 04:21 AM
killerv6
killerv6's Avatar
Default Cat sims
Originally Posted by OH THREE Z
Im in.
I agree with you then l'm in
VictorBarron (03-31-2016)
Old 03-31-2016, 04:30 AM
Seannyc
Seannyc's Avatar
How would this work on a. Stingray
Also if normal long tubes gain 20whp what's the TQ numbers on he manifold vs Longtubes
AMMUSCLE (02-22-2018)
Old 04-14-2016, 10:13 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
I should have the test versions here in about 2 weeks. Sorry it took so long but everything has been done and looking forward to getting these out.
Old 04-15-2016, 12:49 AM
Seannyc
Seannyc's Avatar
How much will this gain on a stingray
Old 04-15-2016, 09:30 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
not tested on a stingray but it wont hurt.
Old 04-15-2016, 01:05 PM
Seannyc
Seannyc's Avatar
I will be intrested in the gain on a stingray instead of adding headers if it gets u similar gains
Old 05-03-2016, 11:03 PM
ccarnel
ccarnel's Avatar
Any updates? Figured these would be shipping by now!
Old 05-03-2016, 11:34 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
The pre production set I got was not lining up. Before it gets made I want to be sure no issues. I'm having 50 made and I don't want people to have bad units. Sorry but my ocd is major.
The following 2 users liked this post by NORCAL-SS:
cmcolumbus (10-24-2018), OLD_GOAT (05-30-2016)
Old 05-22-2016, 02:48 AM
MK4sup_isF
MK4sup_isF's Avatar
Interested to see pic of the actual product. Definitely need to include a plug and play sim. I had my sim with OEM connectors to tap in between the stock o2 connectors. I had this done for my ISF with headers. An extra 100 bucks increase for a plug and play solution will help you sell more actually.
OLD_GOAT (05-22-2016)
To C7 Z06 Main Cat Delete Kit
Old 05-22-2016, 07:55 PM
TopSpeedNeed
Support Corvetteforum!
TopSpeedNeed's Avatar
Default Cat Delete
I want in.
Old 05-22-2016, 08:08 PM
Arctic Blastoff
Arctic Blastoff's Avatar
can this be done on a corsa exhaust,the sound would make ears bleed
Old 05-30-2016, 09:14 AM
ccarnel
ccarnel's Avatar
Any updates?
Quick Reply: C7 Z06 Main Cat Delete Kit
