Check Engine light came on code P1810
Old 06-11-2016, 02:04 AM
SaxyVette
SaxyVette's Avatar
Default Check Engine light came on code P1810
Took it to the shop they pulled a codeP1810. And cleared the light..the read out was
"transmission pressure switch manifold fault"
Engine check light went off for a few miles, now it's popped back on.
I have about 3K on my rebuilt trans. Hope they didn't screw me on the Trans rebuild. Not sure what to do at this point.
all input is appreciated.
Old 06-11-2016, 11:59 AM
SaxyVette
SaxyVette's Avatar
Had a one year warranty on the trans rebuild since expired. This is a tough deal as I was thinking of possibly trading up for a low mileage 'vert. But can't sell or trade with the Light on.
Old 06-11-2016, 12:12 PM
SaxyVette
SaxyVette's Avatar
I have pulled the following codes, besides the 1810 there is:
B0026 HC
B1000 H
U1064 H
U1096 H
U1016 H
Old 06-11-2016, 12:47 PM
SaxyVette
SaxyVette's Avatar
58 SDM 2 codes
B0026 HC
B1000 H
BO-RFA 4 codes
U1064 H
U1096 H
U1016 H
C 2110 H BO-RFA
AO-LDCM
U1064 H
AI-RDCM 1 code
U1064 H
60 IPC no codes
radio no codes
Old 06-11-2016, 10:11 PM
SaxyVette
SaxyVette's Avatar
Well it's a mystery to me..all the code stuff is a bit overwhelming. I do know the orig code doesn't sound like good news. I'm wondering if maybe the trans rebuilder did not replace the trans pressure switch manifold. Not sure of my next move.
Old 06-13-2016, 01:44 AM
BigGun
BigGun's Avatar
What symptoms are you experiencing, just the check light? Any problems with the trans?
Old 06-13-2016, 02:54 AM
Rob 02
Support Corvetteforum!
Rob 02's Avatar
Does your battery have good voltage?
Old 06-13-2016, 08:40 AM
SaxyVette
SaxyVette's Avatar
No symptoms just the light..trans was professionally rebuilt 6/14..Battery is approx a yr old and show's good charging on the dash guage.
I cleared all the old H codes off and the only remaining thing is: 58 SDM it showed 2 codes I cleared that and 1 code remains. Doesn't specify which (1) code remains.
I'll drive a bit today and see if the light may reset and turn off. I guess I could un-hook the battery as well, I suppose it might do something (?)
..gggrrrrrr this stuff is aggravating to be sure.
Old 07-13-2016, 01:44 PM
SaxyVette
SaxyVette's Avatar
Well I needed a time out I guess, my frustration level got high, so I pretty much just ignored the issue for a couple weeks, anyway I cooled down a bit and made the call today to the transmission shop. Talked to my guy down there and he seemed to understand the issue. He mentioned pulling the pan, checking electrical, service etc..going in Mon bright and early..wish me luck
Old 07-13-2016, 04:23 PM
Nasbluec5
Nasbluec5's Avatar
Probably just a faulty pressure switch, I know in dodge automatics its pretty typical. He probably didn't replace it on the rebuild unless you specified it.
Old 07-14-2016, 12:11 AM
SaxyVette
SaxyVette's Avatar
Nas you're probably right..my local mech wrote down the code on a slip of paper with this written on it..
P1810 transmission pressure switch manifold fault
I'm glad it's going back to the orig rebuilder..I know it will cost me a bit of coin but the mgr said it shouldn't be too bad..
here's hoping this will dial me in for awhile..
Old 07-14-2016, 06:36 PM
Rick369
Rick369's Avatar
I'm glad it's going back to the orig rebuilder..I know it will cost me a bit of coina but the mgr said it shouldn't be too bad..
I've read through this thread but still a little confused. When did you have your trans rebuilt? June 2016 or June 2015? If it was June 2015, any reputable shop should cover this repair and not charge any labor cost. If it needs a part that wasn't replaced during the rebuild process but should of been, then the customer paying for the part would be expected.
Old 07-14-2016, 08:53 PM
SaxyVette
SaxyVette's Avatar
rebuilt 6/2014 1 yr warranty expired 6/15 sorry for the confusion, hopefully the cost won't be excessive.
Old 07-19-2016, 08:05 PM
SaxyVette
SaxyVette's Avatar
**Update** went in the shop last mon 8am as requested, supposed to be "done by 5"...haha..todays' Tues around 5pm they just told me sometime tomorrow..something about needing a small hose..(to shaft me with no doubt) ...aw hell who cares long as they fix it right, but the vette tax..ouch, around 3 bills he said, guess I'm getting some new parts and the full trans service for my hard earned coin..
Old 07-20-2016, 04:10 PM
SaxyVette
SaxyVette's Avatar
Done deal I got full trans service plus new parts and a bill for $300. they gave me a 6mo warranty..my car feels good again, he said I'm good to go for couple yrs..
Old 07-20-2016, 04:11 PM
Nasbluec5
Nasbluec5's Avatar
What'd they replace??
Old 07-22-2016, 08:20 AM
CactusCat
CactusCat's Avatar
Saxy, from your other thread https://www.corvetteforum.com/forums...1810-woes.html , looks like they did that $40 part change out as was described. Glad you got your gal fixed and very glad it was relatively inexpensive!
To Check Engine light came on code P1810
Old 07-23-2016, 04:26 AM
SaxyVette
SaxyVette's Avatar
They replaced the $40 trans pressure switch for $90 and charged $187 labor fee for trans service..the rest was "shop supplies" and tax..Still 3 bills OTD was relatively cheap I'd say.
73Corvette (07-23-2016)
Old 07-23-2016, 06:58 AM
CactusCat
CactusCat's Avatar
Indeed it is. I'll take a 3 bill fix anyday! Glad to hear your rollin' along again.
Old 07-23-2016, 10:07 PM
SaxyVette
SaxyVette's Avatar
Well she's purrin' like a dusty pussycat..so onward we go, for my next fix my pass side front signal bulb has quit. Last year was the driver side, and I end up replacing the corroded socket Here we go again..Guys Thanks for the great support and info. This forum is an amazing place..!!.
Quick Reply: Check Engine light came on code P1810
