FS: 2014 LT1 Z51 C7 dry sump 6.2 motor
SoLd sOlD 2014 LT1 Z51 C7 dry sump 6.2 motor with easy 5k in excellent condition $4,200 can ship
Scientific Negotiator
Received 1,836 Likes
St. Jude Donor '07-'08-'10, '14
Very nice...
C7 Z51 Motor
The motor is located in springfield mo. The burn mark is from a exhaust leak, I replaced this motor with a built super charged motor.
Is it plugged and taped up so nothing can enter the motor? The pics you put up don't indicate it is.
You say this is a dry sump motor but it looks like a wet sump motor. Dry sumps don't have the oil cap on the drivers valve cover.
dry sump motor
yes it is a dry sump motor. the dry sump motor has the oil cap to in the valve cover but there is no access hole in the coil covers. & if you look at the second picture you will see the two access holes in the oil pan for the 2 oil lines and there is no dip stick
