Picture Request: Lowering Springs
Received 1,724 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I'm looking for some before and after pictures of those who have lowered the front with the 550lb coil springs. Post a picture and where you got them (Van Steel, VBP, cut stock, etc), and how much you had to cut off (if any). Thanks!
Before
After
Kubs (07-12-2016)
Thanks guys! I like the look palmbeach!
Rajin - so you just cut the stock spring 1 coil? Do you have the gymkhana springs?
The front of my car is really soft so I would like to stiffen as well.
Kubs (07-12-2016)
Kubs (07-12-2016)
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
Yes it did but a lot of weight was removed from the front end. I had a 3-1/2" gap between the top of the tire and the upper fender arch. Now its a bit more than an inch.
I did this 20 years ago, to the '79 that my wife had at the time.....VB&P 360 springs, with 1/2 coil cut.
Kubs (07-13-2016)
OK so about an inch taller than mine. Thanks.
I ordered VBP 550lb springs and I'm going install them as is for now. Once I get the flares on and cover the front wheel a little more, I might cut half a coil or so.
Thanks everyone for the help! If others read this feel free to post pictures. Ill update when I get my springs.
Kubs (07-14-2016)
